Firestore Raw DV files in dvsd codec NOT read by Vegas Pro 8 at DVinfo.net
Old April 26th, 2010, 06:28 PM   #1
Hey all,
I shot a ton of footage using a friend's firestore setup. Very handy.
Except the footage won't drop into Vegas Pro 8.
It plays with VLC and WMP but Vegas is a no go.
The files were recorded as RAW DV, are avi files and indicate a dvsd codec.
Any ideas how to get my 7+ hours of footage into Vegas?
Is there a codec to download or a converter to install?
Thanks.
sincerely,
ian
Ian Slessor is offline   Reply With Quote
Old April 27th, 2010, 11:59 AM   #2
Not to be pushy here but does anybody have a suggestion or option in relation to my post above?
I really need this footage in Vegas Pro 8.
Thanks for any assistance you can provide.
sincerely,
ian
Old April 27th, 2010, 02:43 PM   #3
If you get no better suggestions and since VLC can play it, VLC has the option of sending its output to a variety of file formats, including MPEG, so you may want to try to use VLC to convert it to something Vegas can read.
Normally I would ask you if you have the dvsd codec, but since WMP can play it, I am assuming you do. But it does not hurt to double check.
Adam Stanislav is offline   Reply With Quote
Old April 27th, 2010, 05:31 PM   #4
Hey Adam,
Thanks for the assist.
I wound up thinking, maybe, just maybe, it wasn't captured in DV RAW but in DV-AVI Type-1 or Type-2.
Turns out, with the assist of GSpot it was Type-1...not readable by Pro 8.
So, I downloaded a little program called DV Converter that will transform Type-1 to Type-2 and, voila! It works. Now to convert 7 hours of footage. Oy!
Thanks again.
sincerely,
ian
Old April 27th, 2010, 09:57 PM   #5
I'm glad you found a solution.
Old March 7th, 2011, 05:52 PM   #6
Re: Firestore Raw DV files in dvsd codec NOT read by Vegas Pro 8
Do you have a link for this download?
Kelvin Kelm is offline   Reply
