Transcoding MOV files for vegas pro 9 at DVinfo.net
Old April 16th, 2010, 11:18 PM   #1
Sorry if this has been discussed before, but I did search and had no luck.
I'm editing MOV files from my Canon T2i with Vegas Pro 9. I've been trying MPEG Streamclip to transcode files. The clips play back fine after transcoding, but playback becomes jerky when transitions are added.
Anyone have any troubleshooting ideas? I think my settings are OK - could post them.
Sam Kanter is offline   Reply With Quote
Old April 19th, 2010, 10:51 AM   #2
Contributor
You might try DVFilm Epic which will speed up playback of DSLR quicktimes in Vegas.
There is a new quick start guide explaining how to use it:
DVFilm Epic I Tutorial
Marcus van Bavel is offline   Reply With Quote
Old August 11th, 2010, 12:37 AM   #3
Use the Matrox Codecs and Prism
I've written a tutorial on how to do it here . . . it's easy and fast.
How to Transcode .mov Files using Matrox Codecs | Custom Made Computers
Edmond
Edmond Engler is offline   Reply With Quote
Old August 11th, 2010, 01:23 AM   #4
I also have a blog entry about transcoding DSLR files to matrox codec.
How to Edit DSLR Footage in Premiere Pro CS4 | L.A. Color Blog
Eugenia and I are both moderators from another forum. I sent her the Matrox codec a while back to test the codec quality and pulldown removal result. Before that, Matrox locked their I-Frame HD codec for their hardware product use only. :)
LA Color Pros Blog
Old August 16th, 2010, 09:13 AM   #5
I've used Edmond's method a number of times. Since using it I've had no problems with editing and rendering. I do tend to use a lot of transitions and some effects. Best thing -- it's free.
Burt Alcantara is offline   Reply
