Vegas 9c where is the HDV 1080 intermidiate Template at DVinfo.net
Old March 26th, 2010, 07:06 PM   #1
Hi All,
I couldn't find the answer to my issue so I posted my question here.
I just purchased the Cineform Neo scene and installed it for my Vegas 9. Unlike my
Vegas 8c I couldn't find the HDV 1080-60i intermidiate in the Template.
What am I missing? I should mention that I do have Vegas 9c installed on my PC.
Thanks in advance.
Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old March 27th, 2010, 02:59 AM   #2
Originally Posted by Matthew Amirkhani View Post
Hi All,
Thanks in advance.
Matthew
Hi Matthew, you have to select - Video for Windows (*.avi) as the file-type first, then you will find Cineform in the Template list, then you go to Custom to select the actual template you require.
Steve
Edit: You need the 64bit version of Neoscene for V9.0c if you're running 64bit Vegas
Last edited by Steve Renouf; March 27th, 2010 at 03:01 AM. Reason: additional info
Steve Renouf is offline   Reply With Quote
Old March 27th, 2010, 05:16 AM   #3
Hi Steve
When I want to render out the footage under save as file, I select Video Windows "avi"
but under the Template dropdown I should see the HDV 1080-60i to select which I don't see.
I don't have this problem with Vegas 8.
HEEEEELLLPPPP!!!
Matthew
Old March 27th, 2010, 09:30 AM   #4
This is a major change vegas 8 to vegas 9 - the cineform DI no longer included by sony (in favor of mxf?).
Although you've purchased Neo, your method of accessing the codec changes. Once you've selected avi you *must* go into the custom render settings and select cineform as the codec, and, select the pixel dimensions & so on that you want. Don't forget to check out the controls "configure" button gives you.
Once you've done this, you can enter a new name and save it as a template, which will be visible from the render-as dialog.
If you don't see cineform among the codecs, you might have to reinstall neo... which might best be preceded by an uninstall - best to do this during the day during the week when you can get cineform support. Their authorization scheme is a little, um, arcane sometimes.
Old March 27th, 2010, 10:33 AM   #5
Hi Seth,
Thanks for your help. I tried it and did work just fine for me.
Thanks alot.
Matthew
