Vegas Video discussions from 2006 (Q1Q2) - Page 99 at DVinfo.net
Old May 7th, 2006, 06:18 AM   #1471
Decklink HD Extreme - no Vegas support
Previous versions of Blackmagics Decklink HD Pro were compatible with Vegas for both capture and preview - the new Decklink HD Extreme is not.
The HD Extreme needs the 5.1.1 drivers - Vegas can only operate with the 4.8.1 drivers. We learned the hard way - and I think Blackmagic could be a little more clear on this issue on their site...
It seems to me that Vegas has no native SD uncompressed 4:2:2 support - Premiere Pro has and works perfect with this card.
/Magnus
Magnus Helander, Crossmediageek on G+
Magnus Helander is offline
Old May 7th, 2006, 06:46 AM   #1472
hey Grazie, what would be good would be to have all those standard ol film fx AND maybe a script interface to access teh sample rate.. all in the one filter... now THAT would be good...
as for me being an android... well i can tell u one thing, i dont dream of electric sheep... lol
Oh another not so bad film look is the Magic Bullet MisFire.. awesome quality, BUT, not cheap (render and cash wise) BUT, for the same money, u can grab Edius Pro3 and do virtually the same film filters all in realtime... I actually use Edius as an FX box simply due to its performance.. edius as an NLE.. well.. i wont comment.. but neither of these will emaulte that frame skipping youre wanting :)
Again, vegas is king..
I wonder if we can put 50fps XDCam HD footage and undercrank to 0.50 to get full realtime slowmo... hmm...
Peter Jefferson is offline
Old May 7th, 2006, 08:21 AM   #1473
HDV Dropped Frames Problem!
Just got my FX1e and shoting in 1080-50i now. The playback on the FX1e looks great when I tested it on a CRT TV. (I cant imagine the beauty on a HDTV yet!) However, the workflow below gives gives an average one drop frame, why?
1. Import to Vegas6d via Firewire, internal HD capture.
2. Render to cineform intermediate 1080-50i.avi
3. Import avi on timeline, edit and render.
I notice the drop frame in the avi. I am checking on the m2t now. I used a new Panasonic Pro tape (it isnt HD). I thought if there are drop frames I should notice it during my playback on the TV? If yes this means it occured during the capture. I'm capturing direct to my internal 300GB HDD enabled with DMA. My PC is 3.0GHz single core, 2GB Ram. Please advise, I have a wedding in 2 weeks!!
Sean Seah is offline
Old May 7th, 2006, 08:52 AM   #1474
Cleaning up Vegas templates/presets
Whilst learning Vegas and doing various projects, I have saved various set-ups as (1) render templates, (2) video track fx presets and (3) event pan/crop presets.
Now that I'm through with many of those user-saved templates/presets, I would like to clean up those menus and delete the ones I no longer need. Unfortunately, despite searching this forum and the Vegas instruction manual, I have been unable to discover how to do that.
Suggestions?
Thanks in advance.
Brian Child is offline
Old May 7th, 2006, 12:14 PM   #1475
Sponsor: JET DV
Open the Effects dialog or Render As - Custom dialog. Now select the preset you no longer wish to have. Click on the "X" to the right of the preset name. Repeat until all unwanted presets are gone.
Edward Troxel is offline
Old May 7th, 2006, 02:37 PM   #1476
Thanks very much Edward (I never even saw that "X" before).
I am an idiot.
Old May 7th, 2006, 07:29 PM   #1477
ive done a heap of RnD for flash into PP2, best export is SWF from
flash then do a conversion to Uncompressed AVI. using a third party prog
(AE, or free ware tools) Then import.
If you do a Flash export to UNcompressed AVI any animations in MC's will
not show up.
Ben Mclaughlin is offline
Old May 8th, 2006, 09:39 AM   #1478
Black levels to high
I am having problems with programs edited in Vegas 6d and burned through DVDA3.
Default PAL settings to render the program to mpeg2 eventuate with a washed out image, sharpness of image is lost [expesially when compared to the original] and the black levels are to high [ie not black].
With the help of a friend on another group I tried setting to CBR 8,000,000 and Best setting 31.[this is in PAL]
Analyzing it, I see the black levels are still too high, ie not black, the image lacks contrast [possibly because of the reduced black level] and saturation is down.
Also I notice the pans and tilts are not smooth, a slight jitter in pans, even slow ones, and on a static shot with objects moving across screen.
Also an interlace flicker. The type you get when doing an NTSC / PAL conversion- you can actually notice the interlace lines on moving the top and sides of objects. Yet all this has been done in the what seems to be correct PAL settings in Vegas and DVDA 3.
All scenes were colour corrected using Vegas 6d CC, Secondary CC, vectorscope and waveform. We see that the scopes are set to Studio 16-235. Our DVD's are for screening on a TV, not computer screens so should we uncheck that box? I just did so and notice the blacks are now upped about 10%, from 0% when checked for 16-235 setting. After all we did do the CC for 16-235.[7.5 IRE is not checked as that's for NTSC right?].
Another test. Rendered the same CC'd timeline to avi then to tape. The scenes fed to the same monitor [same as used for DVD to screen] shows better contrast [better blacks] and better colour saturation. So peeling back the layers, it appears i have a problem in the transfer from Vegas timeline to mpeg2 render or in the actual burn.
BTW, how valuable do you find the Colour Curves Fx plugin? I've just used it and it looks like a very efficient way of getting good results quickly.
I'd appreciate your thoughts.
Geoff Jak is offline
Old May 8th, 2006, 10:18 AM   #1479
Try adding the color corrector, with the "studioRGB to computerRGB" preset. Burn a DVD and view it on the same monitor. Do the levels look right then?
2- Wrong field order may explain why you have interlace artifacts? Try the other field order in that case.
Glenn Chan is offline
Old May 8th, 2006, 12:03 PM   #1480
Thx Glenn
We are already in PAL land where I have set the fields to Lower first. I haven't done the test yet [reversing the field]. Why would changing it help when the PAL default is lower?
When changing the CC to "studioRGB to computerRGB"...wouldn't that change the colour/contract to look its best on a copmuter moniotr...which is what i don't want. I need these programs to be seen on a Tv screen.
hx very much anyway.
Old May 8th, 2006, 12:53 PM   #1481
Slash Rules!
Hi. I have had issues that sound similar to yours, when burning DVDs from MPEG2s rendered in Vegas. I'm using Roxio DVD builder to burn the DVDs, but I also get the super washed out blacks. So far, still have not solved that problem. My blacks also tend to go noticably green.
Seems like everything looks right if I watch the MPEG 2 on my computer monitor, but once I have a burned DVD, that's where the problem is, I guess. I haven't tried watching a burned DVD on my computer, I don't think. I've just been living with it, so far.
Josh Bass is offline
Old May 8th, 2006, 01:40 PM   #1482
Originally Posted by Peter Jefferson
For we are the music makers, and we are the Dreamers of Dreams
Sorry Peter - This was quoted by Willy (genius that he was) - It is the first two lines of "Ode" by Arthur O'Shaugnessy. Another is "movers and shakers" - Dont know if that was original at the time but it's this first place I saw it. It's one of my favorite pieces.
Bruce Paul is offline
Old May 8th, 2006, 02:30 PM   #1483
Yeah I've been getting pretty fed up with Vegas lately. It's beginning to feel like a child's NLE. The video in the preview looks beautiful then when I render it to 24p (2-3pulldown) or various other templates I get a slew of visual problems like creases, flickering lines, wavy interlace artifacts, over saturation, bad motion, loss of sharpness, changed aspect ratio, flipped upside down footage, etc.
I've used VLC and Windows Media Players.
I'm about ready to give up on this. Can anyone suggest a Windows NLE that can handle HDV better?
AMD Athalon 2800 (2.08ghz) running Windows XP sp2
1GB of RAM Vegas 6.0 NLE 300+ GB hard drive space
running SATA RAID 0 With an NVIDEA Geforce FX 5600XT
http://www.dvinfo.net/conf/search.php?searchid=149990
Kevin Red is offline
Old May 8th, 2006, 03:16 PM   #1484
Track motion/picture in picture
Hi
I need to create a PIP effect - the Vegas manual suggests using track motion - which is easy enough - but this means the entire track has that motion property which I realise isn't a problem if there's nothing on the track but it seems a bit of a waste of a track.
Is there somthing I'm missing?
Thanx
Ian
Ian Briscoe is offline
Old May 8th, 2006, 05:23 PM   #1485
if the picture inset doesn't need to follow something on the screen, just scale down a second video layer and let it buck...maybe a border under it or something to separate.
Web Youtube Facebook
Cole McDonald is offline
