#1021 |
Old Boot
Ever wanting to Repeat a Script?
Well if you HAVEN'T all the scripts you want as tiny Icons on the toolbar - eh . .I just discovered "View Script Editor" - and yes this is for the knowledgeable creative script editors we can count to be fortunate to have amongst us - but I didn't know about this "Script Editor"? .. Well I do now!
Ctrl+Alt+0 will bring up this View. Once you have browsed for a script and have it in front of you in all its nakedness (. .hmmm .. nice! . .. ) you get to "RUN" the script and if you want to do it again .. just "RUN" it again .. and again .. I've sometimes wanted to run a script without needing to have it on the toolbar; have its one icon and to be able to repeat its results. We have Undo and Redo - but not Repeat Script. This is useful. Try it you might just like it. AND you get to see the innards of the script. . .now there's a thought "Grazie! Put that script editor away!!! NOW!!!" I guess somebody is gonna tell me that there is a simple switch/click to repeat last script?? .. so what DOES "var" mean? . .and "IncTime" ? ? Grazie |
#1022 |
Sponsor: JET DV
Grazie, what app are you looking at?
var means you want to declare a variable. IncTime is probably the variable name declared by the var (but without more reference it's hard to say)
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#1023 |
Old Boot
Ditto! - Eh? vegas. Vegas 6d . .
#1024 |
Sponsor: JET DV
Not necessarily. When you render for computer playback, you'll get the entire frame. When playing back on TV's, there's an overscan area which varies from TV to TV. In other words, play it back on 3 different makes/models of TVs and you'll like see three different amounts of footage.
#1025 |
Sponsor: JET DV
If you wanted to send them to me, I could try to open them in 4, 5, and/or 6. Assuming it does open in at least one of them, it should be possible to work up to a Vegas 6 version.
#1026 |
Old Boot
So you can't ask for 10% back .. maybe a variable of the amount of TVs that obey your rendering . . and as I said, and Edward underlined, render for PC - viz the WMV/WMP I spoke of - gets me ALL my hidden sins "visible" from the borders - oh yes! Done that . . but we'll draw a veil over that mistake - thank you VERY much!!
Grazie |
#1027 |
Bitrate rules! If you don't know what bitrate is, you'd better be for figuring it out. Low bitrate and high motion equal disaster/bad quality. You should likely be in the 8Mbps range for high motion. We shoot a LOT of MotoCross footage, andyou need a high bitrate. Additionally, do you have the stabilization in the camera turned on? That too, will affect the encode.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#1028 | |
#1029 |
Prod Monitor Problems
I've got a JVC H150C hooked up through my Panasonic PC-DV203 cam (firewire -> composite) but can't view any video except individual frames.
If I try to run the video, all I get is a blue screen on the monitor, and Vegas freezes when I stop the video. I have to turn off the little Panny to get Vegas back. DMA is enabled, I've tried changing the Preview RAM and thread count, and video sync settings in Vegas. Nothing helps. Anything else to look for or do? P4, 1 GB RAM, 7200 rpm hard drives, XP Pro, MSI with AMI, Vegas 6.0d |
#1030 |
recording equipment
I'm looking for some recording equipment. Is anyone familiar with the M-Audio Podcast Factory?
#1031 |
Try Heroglyph
Heroglyph has an very frustrating non-standard UI but it does have "path motion" and you should be able to do handwriting - works as a Media Generator plugin to Vegas, 30day demo at
http://www.heroglyph.com/ /magnus
Magnus Helander, Crossmediageek on G+ |
#1032 |
Please Hook Me Up!
Shot a motorcycle race in HDV on Sony HDR HC1. Down converted to Sd as it went from Camera to hard drive. Everything looks great in the timeline-as soon as I render, dump it to DVD using architect 3, all the edges fall apart...? What is a good render template for fast motion SD?
#1033 |
When all was said and done, I had a bad video file, I'll have to recapture that particular file. It was the last file that was 'missing.'
Thanks as always Ed. I wanted to get this file open because it was the one I did the Starwars ending on. Kinda cool.
What happens if I push the 'Red' button? |
#1034 |
Problem fixed. I just re-captured that clip. The m2t file I was trying to swap back was corrupted probably due to a hard drive issue.
#1035 |
I don't use templates, but if I did....I'd use the NTSC DVD Architect video stream
