Vegas Video discussions from 2006 (Q1Q2) - Page 33 at DVinfo.net
Old February 16th, 2006, 01:19 PM   #481
Sponsor: JET DV
Just right-click it, choose Channels, and then "Left Only". Then you can use the Pan envelope to pan from left to right as needed.
Edward Troxel is offline
Old February 16th, 2006, 01:29 PM   #482
I probably didn't explain to well. I already have audio on the left track. I would like to duplicate the left track to the right track creating stereo (kinda). I would then be able to add velocity envelopes to selected portions creating left to right stereo sound.
Sandy Thordarson is offline
Old February 16th, 2006, 01:45 PM   #483
I think you did get the right answer. By selecting "Left Only", you inform Vegas that you actually have a mono track, which you can then pan as you please. Copying the left channel to the right won't make it any better; the stereo phase information does not exist.
Emre Safak is offline
Old February 16th, 2006, 02:09 PM   #484
Ok Thanks for the info guys I'll give it a go and see what happens!
Sandy
Old February 16th, 2006, 02:23 PM   #485
DVD Export? Non Piracy related
I have a friend that shot and had a documentary editing and placed on a DVD. She wants to go back and re edit it and add some music, but only has the completed DVD. Is there anyway to accomplish this?
Thanks.
Heath Vinyard
www.ghostlandmedia.com
Heath Vinyard is offline
Old February 16th, 2006, 02:30 PM   #486
Use a tool to rip the DVD, drop the MPEGs into Womble, and add the music there. This will prevent you from having to re-compress the vid, and maintain your quality.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old February 16th, 2006, 02:33 PM   #487
This is a question I am seeing asked increasingly often. DV Magazine had a feature on this last year: Deconstructing DVDs: Re-Editing Your DVDs.
Old February 16th, 2006, 02:37 PM   #488
Try this
On a PC, Get DVD Shrink from this site or other site. It should be free.
Use it to back up DVD to hard drive in full quality format.
Next, search for a .vob convertor program on internet. I haven't looked lately, but there used to be free ones. You may want to find one that con verts to .avi, since that is easier to edit in, than .mpeg
oops, really don't need DVD shrink because there isn't any encryption.
Chris J. Barcellos
Chris Barcellos is offline
Old February 16th, 2006, 03:13 PM   #489
Sponsor: JET DV
By choosing "Left Only", only the LEFT side will be played on both LEFT and RIGHT. Then you can use the Pan Envelope to pan between the left and right sides as desired. Give it a shot.
There is no "Velocity Envelope" for audio.
Old February 16th, 2006, 03:32 PM   #490
Thanks Edward I got it! Just the way you said. I'm a rookie at this and your help is appreciated.
Old February 17th, 2006, 06:58 AM   #491
How would I achieve the following
I was watching the following clip
http://s12.yousendit.com/d.aspx?id=3...F22JRXYSCW28G6
And I was wondering how I would go about achieveing the black and white silhouette flashing in the background effect, I can't really describe it, so if you watch the video you will understand what I am talking about
Thanks in advance
Scott
Scott Johnston is offline
Old February 17th, 2006, 09:23 AM   #492
Sponsor: JET DV
It looks like they masked out that one person, zoomed in slightly on that the clip, changing it to black and white, lowered the opacity, positioned it so that it was offset the original person, and then made it "flash" (which could be done by lowering the opacity to nothing or by cutting out sections)
Creating the mask would be the most difficult step.
Old February 17th, 2006, 08:59 PM   #493
I get an error every time I render to .Mov
Hey people!
Has anyone ever received an error when trying to render to .Mov I have version 6c. And I work with cineform codec to capture my HDV files from a JVC HD10u. I only have issues when I try to go to .MOV.
John
John Lorince
Http://capturemotion.tv
John Lorince is offline
Old February 17th, 2006, 10:58 PM   #494
u have to have QT installed.. if u have QT pro 7. then your better oif for MOV delivery
as for web content, Vegas is probably the only system which has almost every format at your disposal..
Peter Jefferson is offline
Old February 18th, 2006, 01:00 PM   #495
Originally Posted by John Lorince
...error when trying to render to .Mov I have version 6c...
Reinstall the (free) quicktime and do a custom install - make sure that you include the authoring components. mov should work fine for you after this.
Seth Bloombaum is offline
