Vegas Video discussions from 2006 (Q1Q2) - Page 23 at DVinfo.net
Old January 30th, 2006, 05:15 PM   #331
scrolling credits
Mike, thanks for the reply. Yes my video track was above my generated media track, but after switching them, the fundamental behavior appeared to be the same. However, after some experimentation, I was able to "lighten" the generated media track and it seems to help. Does a level 1 track take precedence (or not) to the level 3 track?
Paul Carlberg is offline
Old January 30th, 2006, 05:56 PM   #332
Paul, I totally missed the line in your first post where you said "Thus, in order to see white text, my video is darkened because my background for the generated media is black". If you mean what I think you mean, you used "Plain Scrolling on Black" instead of "Scrolling on Transparent". Try the Transparent option and it should solve your problem.
Mike Kujbida is offline
Old January 30th, 2006, 06:21 PM   #333
Sorry about the mad rush and all but a $100 rebate and the training DVD deal from VideoGuys was too good a deal to miss. The net price is better than what it would have been if I had bought direct from Sony.
So I went ahead and purchased Vegas+DVD. So it looks like I will become a Vegas user in a few days.
I will still have MSP8 to temporarily fall back to while I get up to speed with Vegas.
Danny Fye
www.dannyfye.com
www.dannyfye.com
Danny Fye is offline
Old January 30th, 2006, 07:53 PM   #334
Sponsor: JET DV
Make sure a watch the training DVD and look through my newsletters (in the Newsletter Archive section on my website). There's also lots of tutorials on the VASST website.
Edward Troxel is offline
Old January 30th, 2006, 07:56 PM   #335
Sponsor: JET DV
You can easily change the background color. Open the Generated Media FX box, on the right side, go to the "Styles" tab, and look at the bottom of that tab. There you will find a "Background Color" box that is set to black. Click on the background color and then change the "A" setting from 255 to 0. This will make the background transparent.
Old January 31st, 2006, 01:55 AM   #336
I do remember someone posting the link to the actual video on Edwards site;
Here's the link
http://thetroxels.com/vegas/forum/viewtopic.php?t=1093
Hope that helps
Scott Johnston is offline
Old January 31st, 2006, 12:08 PM   #337
Underwater Appearance
I am attempting to create a scene where I can place potential sponsors names moving and pausing underwater. I have tried to use 3D modeling with the top underwater area having light rays shine through on the bottom and on the sponsors logo from top to bottom. I was wondering if I should try to use animated water or reel water shot. I checked every VASST Veggie I could and everthing places logo on top of water or just in the water with no top or floor. Any and all ideas is greatly appreciated.
Regards,
Capt Ben
"Chew On This Saltwater Fishing Show"
Fishing Television with Intensity
Last edited by Ben Chancey; January 31st, 2006 at 12:09 PM. Reason: Misspelled appearance in title
Ben Chancey is offline
Old January 31st, 2006, 12:38 PM   #338
The http://www.vasst.com/resource.aspx?i...8-012275582727 file doesn't do it for you? Very easy to make generated water, but if you need something different than the asset listed above, I'd recommend using shots of real water.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
Douglas Spotted Eagle is offline
Old January 31st, 2006, 05:11 PM   #339
re: scrolling credits
Mike and Edward,
thanks the excellent suggestions! Making the generated media background transparent should indeed work but for some reason, my white text disappears. (now I know what Styles-> color-> A0 equals). Anyways, what works well is placing the GM on track 1 (foreground) having video on track 2+, and setting the "composting mode" selection for track 1 to "lighten". My composting mode for track/video is source alpha. Mike, your suggestion "scrolling credits on transparent" is excellent and works, however I am using "timed fade on black". I'm sure if there was a timed fade on transparent, that would do the trick. Thanks guys!
Old January 31st, 2006, 06:39 PM   #340
Steven,
if you don't need the actual drop to be seen, but just be a representation of it, it's easy to build. Gary Gowman has a great tutorial on Sonar Rings that you can find at http://www.sundancemediagroup.com/ve...owmansonar.htm which can easily be modified to make a drop of water appearance.
If you want to see how you'd do that, http://www.vasst.com/resource.aspx?i...0-2b47a51fa358 has a tutorial and veg file, plus downloadable media. It's a project for Vegas 4, but it's still quite applicable.
If you have Ultimate S, building the drop will take about 5 mins, tops. Without it, about an hour, but it's quite simple. If you can't get it quite there, drop me a note, I'll quickly build it for you.
Old February 1st, 2006, 01:59 AM   #341
DSE for some reason when I download that file I don't get any motion. Is there something I am missing?
Old February 1st, 2006, 06:00 AM   #342
"I'm sure if there was a timed fade on transparent, that would do the trick."
In a roundabout way, there is. It's just not specifically called that.
To fade titles from or to black (and keep the underlying video intact), use the "Scrolling on Transparent" option. Place your cursor at the top left or right edge of the title segment and you should see it change to a 1/4 circle with the words "Fade offset 00:00:00:00". Drag this forward or backwards to the desired amount. That's it.
Old February 1st, 2006, 09:51 AM   #343
contains the entire tutorial, that should get you going. You can also download a free water clip.
Old February 1st, 2006, 10:02 AM   #344
Thanks much!
I will get Vegas+DVD tomorow 2-2-2006.
I am looking forward to viewing the training DVD. I've already figured out a number of things when it comes to basic editing. Some of the workflow is a lot like what MSP8 has. I found a bunch of video type tutorials on Sony's site.
Meanwhile, I've been up all night editing and need to get some sleep.
Danny Fye
www.dannyfye.com
www.dannyfye.com
Old February 1st, 2006, 04:30 PM   #345
Hello
Had the same problem still need another program that is easyer to use
http://www.dvinfo.net/conf/showthread.php?t=58209
Barry James is offline
