Vegas Video discussions from 2006 (Q1Q2) - Page 118 at DVinfo.net
Old June 3rd, 2006, 05:13 AM   #1756
Try using the "Match Output Aspect" setting in the Pan/Crop window instead.
Mike Kujbida is offline
Old June 3rd, 2006, 06:59 AM   #1757
Sponsor: JET DV
Another option may be the "Stretch to Fill Frame" option on the "Render As" screen.
Edward Troxel is offline
Old June 3rd, 2006, 03:32 PM   #1758
Aaargh - why is this happening - borders
I don't understand this.
I have 3 video clips on separate tracks one on top of another. I've tried to add the Sony Border (Blurred) to the even on track 1. But it's not working properly. It's giving me a sort of transparent-ish border with the lower layers showing through. It doesn't matter whether I do this at the clip level or the track level. If I SOLO track 1 - or mute the others - it all works fine. I've checked the opacity of track 1 and its set to 100%. No track motion or pan/crop.
There are NO effects on the lower tracks/events or media. No compositing - nothing.
Help!
Thanx
Ian
Ian Briscoe is offline
Old June 3rd, 2006, 03:37 PM   #1759
Jubal 28
That's the way it works -- it makes the edges transparent. Either have nothing below the clip, or put a black card under it.
David Jimerson is offline
Old June 3rd, 2006, 03:42 PM   #1760
David
Oh my god - of course it does - and that explains how you'd get different coloured blurred borders doesn't it. We have a phrase in the UK - "What a Plonker" - that's me.
Thank you so much.
Ian
(obviously a Vegas novice)
Old June 3rd, 2006, 03:48 PM   #1761
Jubal 28
Any time a Vegas effect preset icon has a little checkerboard in it (though it's admittedly harder to see in the "Soft Edge" icon), it means it's putting in an alpha channel, a transparency.
Old June 3rd, 2006, 05:35 PM   #1762
I don't see anything that looks quite like that. Don't suppose you can walk me through it?
Sorry, Edward, I tried the "Stretch to Fill Frame" to no effect.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline
Old June 3rd, 2006, 06:21 PM   #1763
Did you try the stretch to fill frame in the pan/crop window?
www.24kblack.com
Torrance Colvin is offline
Old June 3rd, 2006, 06:24 PM   #1764
Originally Posted by Robert Knecht Schmidt
I don't see anything ("Match Output Aspect" setting in the Pan/Crop window) that looks quite like that. Don't suppose you can walk me through it?
Put a clip on the timeline. Click the "Event Pan/Crop" button (small square button near the top right of the event). Now right click anywhere in this new window and select "Match Output Aspect". If you watch your clip (in the preview window), you should see it get slightly larger, eliminating the black borders. That's it.
Old June 3rd, 2006, 07:49 PM   #1765
Thanks for walking me through that, Mike--unfortunately it didn't change anything. As I said in the original post, in the preview, the clip looks as I want it, but when I choose Render As... it seems to ignore what's going on in the preview and does its own thing.
ETA: I tried adjusting the crop borders in the Event Pan/Crop window to close over the black borders, and this seems to have worked.
It says Yes by default.
All the best,
Robert K S
Old June 3rd, 2006, 11:43 PM   #1766
Track missing after Render
Hey all,
I am currently doing a wrestling DVD for a company, and I am having the following trouble.
I have on Track 1 and 2 the full match and audio
Then on tracks 3 5 and 7 I have the instant replay set up. I have that working fine and everything seems good on the preview window, but then when I render it out, it is missing out the first instant replay.
It just plays on as if the instant replay isn't even there, but when it comes to the next replay screen, one minute later it works like a charm.
Does anyone know why it would completely miss out something on a different track even when it shows up on the preview window and plays another replay on the same track fine ?
This is probably hard to understand, so if anyone needs anything explained further I'll clarify on it
Thanks in advance
Scott
Scott Johnston is offline
Old June 4th, 2006, 03:40 AM   #1767
fading multiple tracks as one
Well - I must say I'm having a load of fun editing my first wedding video using Vegas - and the help I'm getting from this board is fantastic. But sometimes it's the simpler things that I struggle with...
I've made quite a nice picture wall using event pan/crop and track motion - I have 12 tracks stacked on top of each other. I now want to fade out the entire wall, not each individual clip. The only way I've worked out how to do this is to put a black solid as the top event starting opaque and use keyframes to decrease the opacity at the end. I probably can't see the wood for the trees - is there an easier way?
Thanx
Ian
Old June 4th, 2006, 04:18 AM   #1768
That's what I do - except I assume you meant to say: the solid black starts transparent and increases to opaque?
Martin at HeadSpin HD on Blu-ray
Martin Mayer is offline
Old June 4th, 2006, 04:22 AM   #1769
Martin
I sure did mean that. See - intensive editing puddles your brain!
Thanx
Ian
Old June 4th, 2006, 05:30 AM   #1770
Ian, there are two "Fade In-Out Cursor" scripts on the VASST site at http://www.vasst.com/search.aspx?tex...n-Out%20Cursor that should do what you want. Make sure to do a CTRL-A (select all) before running the script.
