Vegas Video discussions from 2006 (Q1Q2) - Page 117 at DVinfo.net
Old June 1st, 2006, 04:58 AM   #1741
yeah its your video overlay driver.. most likely this is an ATI gfx card?? i get this too.. also happens with media player sometimes, and when u resize the frame, u can bringback the image
Peter Jefferson is offline
Old June 1st, 2006, 03:55 PM   #1742
Excalibur: How do I get a cut instead of a dissolve?
Subject line pretty much says it all…
In Vegas 6.0:
I’m using/trying Excalibur 5.0.3 demo (I own Excalibur 3)… I’ve added cams 1a and 2a to the toolbar, but when I use them (after running multi-cam), I get dissolves instead of clean cuts. How do I set the buttons to cut instead of dissolve?
PS -- Edward, I wish you well -- speedy recovery!
James Binder is offline
Old June 1st, 2006, 04:53 PM   #1743
Duh... 'c' for cut
answered my own question!
Old June 1st, 2006, 07:02 PM   #1744
After I have printed to tape, I will use that same file (after a few adjustment on the properties) and go to DVD architect. With the audio being -20db it will sound very faint on dvd architect. What audio levels should I raise the master up to for my destination??
Fred Foronda is offline
Old June 1st, 2006, 08:17 PM   #1745
Originally Posted by Don Bloom
Tape will produce a "real time" sound and if you don't lower the master level it will snap crackle and pop-remember that -12db in digitalspeak is the same as 0db in analogease and 0 will clip (so will -12 on tape)
just reprint the project anf you lower the master level and you should be set to go
Don
Actually, in "analog-ese," 0dB is the same as -20dBFS. However, WAY too much attention is paid to these numbers. The bottom line is that you want your output peaks to be in the range of -3dB to -.5dB, depending on the content and dynamics. If you are making work for broadcast and have more than 12dB of dynamic from your average, you've likely got too much happening and you need to level things out.
regarding reference scale/dB matching, www.atsc.org, read the whitepaper on levels.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old June 1st, 2006, 08:47 PM   #1746
Sponsor: JET DV
Yep, "A" cameras dissolve "A"fter the marker
"B" cameras dissolve "B"efore the marker
"C" cameras "C"ut
"D" cameras do a standard "D"issolve centered on the marker
I'm sure you'll see that the Multi-cam tools have grown a lot since version 3 and is also now much faster as well. Since you're on Vegas 6, you don't even need to stop playback of the timeline in order to add new camera switches. Plus, you'll see that the tallys also dissolve indicating the length of the dissolve for you (naturally the tallys "cut" when you're using cuts).
Edward Troxel is offline
Old June 2nd, 2006, 12:23 AM   #1747
A1u Low cut duplicate with Sony vegas?
I have the A1U and like the idea of the low cut filter, but actually like the sound better from having the filter off. I, of course, get extra noise this way. Does Sony V have built in audio filters to adjust for low noises?
Thanks guys
Michael Stowe is offline
Old June 2nd, 2006, 07:13 AM   #1748
I wouldn't call it a "duplicate" but yes, Sony Vegas (and most other NLE's) have a low cut filter. The filter in A1u is passive, meaning it's not intelligently seeking a frequency and its harmonics. Doing the same thing in post is usually quite simple.
Old June 2nd, 2006, 09:46 AM   #1749
DVD Architect and PCM rendering
I am rendering a fairly short piece on DVD Architect (about 30 minutes worth of video). Are there any disadvantages of rendering audio using PCM rather than AC3, other than it taking up more disc space given its uncompressed nature. The quality of the audio seems better with PCM and the volumn is quite a bit louder on the DVD.
Can all DVD players handle PCM? What about playback on computer laptops?
Thanks.
-- Keith
Keith McLeod is offline
Old June 2nd, 2006, 09:51 AM   #1750
Audio standards for DVD are either PCM uncompressed, or AC3 Dolby Digital
Elective formats are MPG2 and DTS
for a DVD player to carry the dvd logo it MUST be able to play AC3 AND PCM, therefore, u shouldnt have any issues with the compatibility.
as for volume levels, the ac3 encoder within vegas is fully customisable and there are many threads on this forum which detail its nuances
Old June 2nd, 2006, 10:36 AM   #1751
ParticleIllusion problems
Hi,
I tried asking this elsewhere and am still frustrated; I hope it's a simple error I'm committing....
I'm importing a 720 x 480 10-second clip into ParticleIllusion (PI)
as a background, adding my effects (in this case, snow),
then removing the background and rendering only the snow as
a TGA with alpha channel.
In Vegas, I am importing this TGA file as an image sequence and placing it above the desired footage on the timeline--and now it is snowing on my desired footage. Here are the problems:
1) the TGA file sequence has a size of 598x480x32, even though the project settings in PI were set to 720x480.
2) For whatever reason, the snow effect is at least twice as fast as it was in PI. In other words, after rendering it in PI, it is now snowing twice as fast as intended, plus what looked like snow in PI, now looks like square snowflakes;
In Vegas, I right click on the PI created file, select properties/and have these settings:
attributes: 598x480x32
format: Targa RLE
frame rate: 29.970 NTSC
field order: none (but I have tried changing it to lower field first with no success)
pixel aspect ratio: 0.9091 (NTSC DV)
alpha channel: pre-multiplied
When I right click the video file/properties/I have these settings:
720x480x24
format: DV
field order: lower field first
pixel aspect ratio: 0.9091 (ntsc dv)
For whatever reason, I'm still getting the special effects (snow) at what looks like twice the speed--maybe even faster than that--from what I created in PI. Yet the frame rates show they are identical.
And despite setting my settings for 720x480 in PI and hitting alt +3 before rendering, the size--as you can tell by the properties--is different.
Any help greatly appreciated!
--Dale
Dale Nicholson is offline
Old June 2nd, 2006, 10:55 AM   #1752
Yes -- ver 5 looks great. Thanks for the reply -- be well!
Old June 2nd, 2006, 01:40 PM   #1753
Vegas color correction tools
I am wondering, what is the advantage of paying a Co. like DVfilm to do uncompressed color correction on DV files destined for filmout as oppossed to doing it with the Vegas color correction tools. Thanks!!!
Brian K Jones is offline
Old June 2nd, 2006, 03:00 PM   #1754
Washington Baltimore Vegas User Group (WBVUG) Meeting
Mark your calendars!
The next Washington Baltimore Vegas User Group (WBVUG) meeting will be held on Thursday, June 29th 2006, from 7:00pm - 8:30pm in Washington DC, NW. We currently have reserved an auditorium that seats 100 people so there is plenty of room for everyone.
So come on out and meet your fellow Sony Vegas video editors located in the Washington DC, Baltimore MD and Northern VA area!
Thanks and we hope to see you there.
For information, click here: http://www.oicproductions.net/wbvug.html
Mickey Grackin
mgrackin@oicproductions.net
Mickey Grackin is offline
Old June 3rd, 2006, 01:48 AM   #1755
"Render As..." undoes Track Motion on my clip
I'm trying to make a 256k Windows Media Video file for the internet from some XL1 footage, but first I want to get rid of the infamous black border bars.
I take my clip into Vegas, click the Track Motion... button on the video's track, and increase the dimensions of the clip to "grow" it enough so that the black border bars no longer show. The clip previews correctly.
Then I choose "Render As..." WMV, render, sit back and wait.
But the rendered WMV file still has the black border bars, as if the Track Motion enlargement was never applied.
What am I doing wrong? Thanks for the advice--
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline
