Vegas Video discussions from 2006 (Q1Q2) - Page 111 at DVinfo.net
Old May 23rd, 2006, 09:34 AM   #1651
Why doesnt H.264 rendering work in Vegas?
I'm trying to render my 1080-50i to Quicktime H264 but an error pops up. No matter what settings I apply for the rest of the parameters, the error comes. Is there a specific set of parameters to ahere to?
Sean Seah is offline
Old May 23rd, 2006, 09:47 AM   #1652
Do you have Quicktime 7 installed?
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old May 23rd, 2006, 10:42 AM   #1653
Color correction in vegas
ok, still looking at different editing options before i buy. I was wondering how involved is the color correcton in Vegas. I ran across a sample of color correction doen useing a program called magic bullet. Is vegas on par with this, or is magic bullet a special software made for color correction. Any help would be great
Wish I had something witty to say
Tim Goldman is offline
Old May 23rd, 2006, 10:53 AM   #1654
Magic Bullet isn't for color correction, but rather color "enhancement." MB is for generating filmlooks more than anything. That said, with a little creative ability and a fair amount of time, you can get Vegas to do the same thing. The color correction tools in Vegas are plentiful and very good, and generally real time on a reasonable machine.
Old May 23rd, 2006, 03:09 PM   #1655
Jubal 28
I would agree. There's little you can't do with Vegas's own tools.
David Jimerson is offline
Old May 23rd, 2006, 03:22 PM   #1656
Ed, glad you are back. Hope you are feeling ok. I decided to remove the desk top icon and just leave Vegas 5 on the computer, it really does not take that much room on the drive. Bob
Bob Safay is offline
Old May 23rd, 2006, 04:35 PM   #1657
Magic Bullet Editor's 2 is a filter/plug-in that works in many NLEs, including Vegas.
MBE (the original) renders very very slowly. About 30:1, but it depends on what settings are on and what machine you have.
MBE2 allows for GPU acceleration... but with specific graphics cards. See the website for information on how to get 'real-time' performance out of Magic Bullet.
Magic Bullet Suite adds 60i to 24p conversion. Vegas does a very good job of that type of conversion itself. Vegas is *much much* faster and (I believe) a little lower quality.
I think MBS is After Effects only. It'll work with any NLE if you just export files into AE for processing.
And I believe there's also Misfire, which adds film damage and transitions.
2- You can get the same idea as the MBE looks in Vegas using Vegas' tools (the maths are slightly different).
VASST Celluloid uses Vegas' tools to create looks, and makes the process easier. Because Celluloid uses Vegas' tools, it can render much faster (unless you have a Geforce 7800 and GPU acceleration working).
But anyways, if you use Vegas you definitely have options. If you like MBE or MBS then you'd be able to use those tools.
*Disclaimer: Incidentally, DSE David and I are all affiliated with VASST.
3- You can get an idea of what you can do with Vegas' tools alone in the following clip:
http://www.glennchan.info/Proofs/dvi...comparison.mov
11.3MB download (my web server is very slow unfortunately, so it'll take a while to download)
Glenn Chan is offline
Old May 23rd, 2006, 05:18 PM   #1658
Sponsor: VASST
Sean, There should be no guesswork in what the footage actually is regardless of your preview window. Just right-click on it as I said and read the properties from the file. What do they say? Does the format say DV? Does the pixel aspect ratio say PAL DV or PAL DV Widescreen? That will tell you what it is.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline
Old May 23rd, 2006, 05:29 PM   #1659
Yeah. But it 7.0.4. Downloading 7.1 to try it out now.
Old May 23rd, 2006, 06:05 PM   #1660
If you have Vegas 6.0d, it now includes the MainConcept AVC codec, which is H.264.
So render to Mainconcept AVC .mp4 instead. Works fine.
The MP4 container format is preferred over MOV for H.264, even by Apple.
Gian Pablo Villamil is offline
Old May 24th, 2006, 12:55 AM   #1661
"The MP4 container format is preferred over MOV for H.264, even by Apple."
Makes u wonder hey.. lol
Peter Jefferson is offline
Old May 24th, 2006, 08:34 AM   #1662
Image size
Hi,
I am planning on doing some timelapse still image capture on my Sony HC1. This sequence when assembled will be added to a project using the HDV 1440i template -capturing the compressed output from the camera. Eventually I aim to output to a Blue-Ray disk although for the next 12 months I will have to settle for standard PAL DVD or play output from Hard Disk
My question is this: for best quality what image size should I select in the HC1? Options that look likely are:
1. 1920x1440
2. 1920x1080
3. 1440x1080
The first looks sure to squash the image in the vertical direction but what would 2 and 3 do? (HDV 1440 uses 'rectangular' pixels...)
Any help appreciated.
Regards, Nick.
Nick Outram is offline
Old May 24th, 2006, 08:48 AM   #1663
Oic.. I'll give it a try. Trying to toy with this as the HDwmv doesnt run well on my 1.83Ghz laptop. Works fine on the 3GHz desktop. I hope the mp4 will work better.. Thanks!
Old May 24th, 2006, 09:01 AM   #1664
If you have a horsepower issue, and WMV doesn't play well, then H.264 is going to be even harder. Try an older MPEG4 codec like XVID instead. Single pass mode with quantizer at 2 or 3 is very good quality. Don't use single pass mode with a fixed bitrate.
H.264 is nominally part of the MPEG4 standards, but actually has little in common with previous MPEG4 codecs (eg. Divx, XVID, 3ivx). It requires more CPU to encode and decode, but is more efficient in terms of quality/size.
Old May 24th, 2006, 02:39 PM   #1665
Sponsor: VASST
I am not familiar with the HC1 (I have a Z1) but my guess is that the still image capture is using a pixel aspect ratio of 1.0 so 1920x1080 is the way to go if you are going to output to HDV.
~jr
