Vegas Pro 9 64-bit upgrade question at DVinfo.net
Old February 2nd, 2010, 08:00 AM   #1
I'm getting ready to upgrade my computer to 64-bit. I checked out these two articles.
Videoguys Blog - Videoguys' DIY7.7: Intel Core i7 with Vista 64 AND Now Windows 7
Answer
I decided to go with the suggested hardware at Videoguys. I have two questions,
Currently I am using Vegas Pro 9.0c 32-bit do I need to purchase the 64-bit version of Vegas
Pro 9? Will Magic bullet looks 1.2 be 64-bit capable?
thanks,
-kAj
http://www.sweetproductionmedia.com/
Kajito Nagib is offline   Reply With Quote
Old February 2nd, 2010, 08:09 AM   #2
Sponsor: JET DV
When you purchased Vegas Pro 9, you purchased both the 32-bit and 64-bit versions. All you need to do is download the 64-bit version and your serial number will work in it as well.
As for Magic Bullet, it currently does not work in the 64-bit version. I don't know if or when they will support the 64-bit version.
Old February 2nd, 2010, 08:14 AM   #3
thanks Edward. Is there a way to work around this?
Can I work in 64-bit for my editing then switch back to the 32-bit version of Vegas when I need to use the MBL's plug-ins?
-kAj
Old February 2nd, 2010, 09:48 AM   #4
Sponsor: JET DV
Yes. You can install both 32-bit and 64-bit on the same machine, do all your editing in 64-bit, save the project, open in 32-bit, apply Magic Bullet, and then render. However, I would tend to simply only use effects that are available in both 32-bit AND 64-bit. There are many that are.
Old February 2nd, 2010, 01:35 PM   #5
ok so the .veg will open in either one. thanks.
-kAj
