error message
I am having a blue screen crash/error when previewing in Vegas. Here are my PC details:
8 Gigs RAM Quad Core processor ATI radeon HD 4650 video card 160 HD for OS 1 TB internal HD 750 external HD Windows 7 ultimate 64 bit vegas 8 32 bit version the only time I have issues is when previewing clip. It plays for a minute or so then it crashes. Not everytime but enough that it seems like there is an issue. I have also had issues rendering with MB filters applied. No matter what I do when I render a clip with 1 MB filter applied it stops at 21 or 22% (30 minutes) every time. Here is the error I get when it crashes: Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional information about the problem: BCCode: 124 BCP1: 0000000000000000 BCP2: FFFFFA8007AD6028 BCP3: 00000000B406A000 BCP4: 0000000053000145 OS Version: 6_1_7600 Service Pack: 0_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\012710-19921-01.dmp C:\Users\Steve\AppData\Local\Temp\WER-46706-0.sysdata.xml Any help is greatly appreciated! |
...anyone?
It sounds like you might have some corrupt media in your project, especially if it is crashing at exactly the same point each time.
Try rendering it again exactly as it is now and make a note of the frame number when it crashes (if you're getting a blue screen crash then you'll have to stare at the screen during the render I'm afraid, or at least from about 25 mins/20% onwards). Now, locate that frame number on the project timeline and identify the media at that point. Try removing it (one clip at a time, if there is more than one clip at that point) and re-rendering. You should quickly find the culprit, which should then be ditched or repaired (try rendering it out from a new .veg with no effects and then replacing the sick clip in your project). Hope that helps. There may well be other possible causes rather than corrupt media, but given that your crash occurs at the same place each time, this is where I'd lay my money. I used to live in Columbus, in a previous life. I blame Max and Erma's for my weight problem . . . |
Thanks for your response! I've tried it with different clips so I don't think it's corrupt media. I think it is a PC issue and not necessarily a Vegas issue. I took it to work (Best Buy) and had the Geek Squad look at it. I tried to make it crash by rendering a file with an MB filter applied and it, of course, rendered it perfectly! I think it might be a bad sector(s) in my hard drive. Running some tests on it right now. Wish me luck!
yea, Max and Erma's have added a few pounds to me as well. Their Garbage Burger is awesome! |
#5 |
Yes, run a disc check and that should take care of it.
