Image Sequence Scripting Error - help anyone? at DVinfo.net
Old January 25th, 2010, 11:36 AM   #1
Hi there.
Upon someone's great suggestion, I tried 'simulating' time-lapse of a real-time filmed sunrise by using the script for doing an Image Sequence (every 12 sec's) and rendering to PNG files to be composited later.
Trouble with the script - the first 60 or so .png files are HALF the size of the remaining .png files? What's causing this? (The first batch are about 525kb and the last batch are HD quality - about 1200+kb.
Any solutions to this weirdness?
Please & Thanks!
Martin
Martin Bannet is offline   Reply With Quote
Old January 25th, 2010, 12:11 PM   #2
Sponsor: JET DV
Make sure the project is set to "Best - Full" and the project settings are the same. The images are output at the resolution of the preview display. The script SHOULD have done that for you but you can change it yourself just to make sure.
Old January 25th, 2010, 12:32 PM   #3
Yup! That was the ticket!
Thanks Sir!
Much appreciated!
Martin
