Time lapse/Virtualdub at DVinfo.net
Old January 9th, 2010, 02:40 PM   #1
Any one here had have used virtualdub to do your time lapse with still photos? if so, can you please post some detail how it is done. Ive try but it don't seem to work. I got 100 still pictures and all have been renamed in this order # 1 - #100 when I try to import the picture I got this error JpegDecoder Unsupported encoding. And other times I am able to load the Jpeg just fine but I got the same error message when I save it. Your input is appreciated.
Bruce Phung is offline   Reply With Quote
Old January 11th, 2010, 08:00 AM   #2
Sponsor: JET DV
I just use Vegas - it can load image sequences just fine.
Old January 11th, 2010, 11:32 AM   #3
That's odd - I just open the first image in the sequence and Vdub automatically loads all of them, one per frame.
Are they huge images that are perhaps creating a memory issue?
Try resaving (and resizing?) a few in an image editor and see if those will load.
(If you find that works, there are freeware batch jpeg tools that would let you resave your whole sequence painlessly).
Old January 11th, 2010, 11:41 AM   #4
Originally Posted by Bruce Phung View Post
...all have been renamed in this order # 1 - #100...
Try renaming them 001 - 100 and see if that helps.
Old January 11th, 2010, 01:50 PM   #5
Edward, will you please tell me how it done in Vegas with still image because I can't figure it out how it done.
Graham, the still image are not huge and memory? I got 6gig DDR3 should not be a memory problem at all.
Mike, I try to rename as you suggested 001-089 and does'nt work. What odd about is that, example, I load image 001 and I got an error, unsupported JpegDecoder. I then load image 002 and it load fine but just 1 image, when I try to load image 089 and got an error.
Old January 11th, 2010, 02:18 PM   #6
Sponsor: JET DV
File - Import - Media, pick the first image in the list, and on the bottom of that dialog check the "Open Still Image Sequence" checkbox and make sure the ending number is correct.
Old January 11th, 2010, 05:03 PM   #7
Edward,
Thank you. Image sequence only allow 1-21 still pic at a time? I got 1-89 but it will only allowed me to do 1-21. I change the ending number to 89 but it still showing up last number as 21. Any more tips?
Old January 11th, 2010, 05:46 PM   #8
Bruce, in my experience, the only way this can happen is if all the images are not sequentially numbered.
My guess is, that if you take a look, you'll see image #21 and then image #23 which is why it will stop at image #21.
Old January 11th, 2010, 06:19 PM   #9
Mike,
You are right. I went back and look, it missing 22. Thank you.
Old January 13th, 2010, 03:47 PM   #10
select all the photos and drag them on the timeline. Vegas will automatically add the photos back to back on the timeline in the order they were in the folder. be sure to drag them from the first image, as w/e image you drag from will be placed at the start of the sequence.
To set the duration of each photo on the timeline go to preferences -> editing tab -> new still image length. The value .07 gives you 2 frames per image (15fps @ 29.970) and is a good starting point. you also want to make sure the "automatically overlap multiple selected media" is not checked - it will screw you up.
Arri Arava is offline   Reply With Quote
Old January 14th, 2010, 09:01 AM   #11
Sponsor: JET DV
Arri, what you said adds all images to the timeline (as you said) but as a separate event for each picture. When adding as an "Image Sequence", each photo is automatically "1 frame long" and the entire sequence appears as ONE event instead of hundreds.
Old January 14th, 2010, 06:45 PM   #12
True, both ways work. I use the one I described since it allows for easier individual image control. the beauty of vegas is that you can do the same thing in two or three different ways, some benefiting a specific workflow.
