How to change Font Sizes in Multi Cam Mode
I am wondering if someone can tell me how to change the FONT sizes so i can actually read them when in Multi Cam mode.
I am able to create a Multicam track, but can not view if its CAM A, CAM B, etc in the preview window because the fonts are so tiny. I have tried making the preview larger as well, but this does not help either. Thanks... Dave
Vegas 8.0c (Build 260)-(Upgraded to Sony Vegas 10 pro)Canon GL2, Canon HV30, HF200, HF20-Sony UWP Wirelesss Mic Kit, Intel Core 2 CPU-6600@2.40GHz-3.00GB Ram |
Yes, and the interface font too. it is amasing how you can reconfigure everything in the program. but on a very high resolution monitor these numbers everywhere are like little fleas that landed on the screen :-)
For the Takes view problem there are a few things you can try. Change the project video properties, then make sure you switch them back before render Change the "PREVIEW" quality , try preview or Draft , Full, as the quality <--- this one changes stuff a LOT. Preview on external monitor, even if you dont have an external this will give you a full screen display. Rename the video Files using all Caps :-)
----------------sig----------------- Re-learning everything all over again, one more time. |
