#31 |
Well FCP may not be perfect and yes it's missing BR support ( this will come) but in general I find FCP easy and does exactly what I give it from a 30 sec cut to a 2 hour cut.
For me also is the stability of Mac's that I work on from a MBP to a tower and sure FCP locks up but so has every other NLE I have used including Avid MC. I used to think, why FCP and Mac but I get now. Cheers |
#32 |
sucks to hear the trouble people are having with vegas. I too have been dissapointed with the recent versions and lack of quality control. the app's recent instability has also made me question moving to a different NLE. seems like anything sony gets its hands on turns to sh!t after a while.
#33 | |
#34 |
Do you mean sticking with Cineform inside Vegas or CanopusHQ inside Edius? I'd go for Edius to be honest.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
#35 |
I actually meant using Cineform inside Edius Neo 2
#36 |
Ah ok. Well give it a shot. There's a lot I like about Cineform. A few things I don't, but hey...
However, I would think that CanopusHQ would be optimized well for their products. I'd do some A/B testing and see...
#37 |
Perrone, I was looking at the following...on the Grass Valley website it said this was their flasgship product...so naturally that is what I checked out....like I said, yikes.
Grass Valley | EDIUS HD Boardset & Software | 600292 | B&H |
#38 |
Jeff - take away about $600 of that total price on B&H and that's the cost of the hardware. I'm doing a 30 trial of Edius Neo 2 right now and other than not having scopes, it does everything I've been doing in Vegas - since my primary delivery is the net right now, I figure if I can get into a work flow methodology that can be used with the full blown package at a later date - why not.
Consider the full Edius package much in the same way as Avid MC software only - no hardware to work with, but you can at a later date add on if needed. Not a bad way to go actually. |
#39 |
Jeff you can run Edius 5 in pure software mode. If you are using HDV there is no need to convert to HQ just use straight on the timeline realtime. I am just editing multicam 2 tracks of HDV from FX1's and a track of XDCAM EX3 1920x1080P native realtime on my Q9450 running VISTA64. IF you need to monitor realtime on a full HD monitor you can get the SPARK card which is just a HDMI output card for the preview screen only. The SPARK will work with Edius and Neo. IF you want input other than iLink from your motherboard (ie HDMI) then get the STORMHD and for analogue input get the STORMHD with the analogue BAY. Personally my system is just software. For AVCHD you will still need to convert to HQ ( which I do for my XR500 video until they port the Booster pack to Edius!!!).
Still use Vegas just for audio and to output encode for Architect with named markers etc. I export a HQ file from Edius and bring into Vegas for final audio and export.( only use for Vegas at the moment so I just use 8.0c!!!!) Ron Evans |
#40 |
There is something else going on in this thread and I'm not sure what it is. Maybe it's nothing more than a "lack of sleep and a purple brain." The most likely source of many of the "problems" mentioned in this thread is probably between the keyboard and the chair.
The ONE thing I do know is that I use Vegas every day and I don't see problems like those eluded to in this thread. If these problems were Vegas itself, they wouldn't selectively appear in only some systems. A particularly vulnerability that Vegas has is that it can be run on a wide variety of systems - - including those that are "whacked" by the user none of which would ever admit that they don't know everything there is to know about computers. i would encourage those who are reading this thread to realize that it's a good idea when reading a forum to look for the main body of understanding from a wide range of people. This is the best way to avoid being mislead by either fan boys or people with an "alternate" intent. |
#41 | |
#42 | |
#43 | |||
I'm not sure what "whacked" is, but all my editing systems are installed the same way. Fresh OS install from scratch. Load NLE, load NLE support programs (GSpot, VLC, VirtualDub, Mpeg Streamclip), patch system. Done. I even went to open a help file on the Win7 system yesterday for one of the apps, and it couldn't because I hadn't installed Acrobat Reader. I run these system CLEAN. Quote:
I've worked with Vegas now for going on 6 years. I've cut everything from conferences, to promos and spec commercials, to movies on it. I've had my issues with it over that time but all had workarounds. The lastest stuff I and others are seeing in the newest versions is far more challenging because a lot of times there is no viable workaround. I've championed Vegas in the past, and it's still a good tool for many, and for certain kinds of work. But it's been a letdown for some workflows. Particularly those originating with mpeg4 based material.
#44 |
Peronne, I have to agree with Brian on this one. I believe many of the problems that people see with any NLE are actually a Windows issue. If you really want to hear some major whining, talk to a bunch of Premiere users. On the issue of Windows induced NLE "bugs", Vegas is fortunately less affected than most NLEs but there is no way to make it immune.
I can understand why some of the NLE publishers require that their NLE be run only on an approved system - - otherwise you're on your own. |
#45 | |
On the issue of Windows. I am amazed at how many people use just one computer for everything. My editing PCs are just for that. Clean, no virus checking etc, nothing, only go to internet for program updates. Never have any problems with any of the programs. Have just one cheap computer for email and browsing. It has lots of protection!!! It too has no problems.I have 4 Windows computer s with no problems. Ron Evans |
