Dot MOV; no vision at DVinfo.net
Old December 6th, 2009, 05:25 AM   #1
Dot MOV; no vision
Heres a curly one for Vegas and HD users...
A client of mine shot and cut a HD vid and saved it as an dot MOV (quicktime) file. its 200Mb in size and runs for 60 sec.
Nothing will open the vid.. not Quicktime, not Windaz Media Player nor Vegas - which is format agnostic.
Opening the file I get audio but NO vision.
Any ideas?
(I changed the file extension a couple of times but to no avail...)
Ben
Ben Longden is offline   Reply With Quote
Old December 6th, 2009, 08:49 AM   #2
Sponsor: JET DV
It all depends on what codec was used inside that MOV file. It appears you do not have whatever codec was used installed. MOV files are just like paper sacks - you can put anything in them. You just don't have what it takes to read it.
Old December 6th, 2009, 09:21 AM   #3
Yes, and Vegas is not format agnostic. It needs the codecs installed like any other program. So ask him what he used EXACTLY to create that video.
Old December 6th, 2009, 11:28 AM   #4
Sponsor: VASST
If your client did this on a Mac, chances are the video codec used was the Apple Intermediate Codec (AIC) which is not available on a PC. Your client will have to render it to a format that is available on a PC like the Apple ProRes422 HD codec. They could also render to an MXF file which Vegas can use.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply With Quote
Old December 8th, 2009, 05:10 PM   #5
Would G-Spot help Ben identify the codec? GSpot Codec Information Appliance
Ian Stark is offline   Reply With Quote
Old December 8th, 2009, 08:10 PM   #6
Absolutely! I use it all the time.
Old December 8th, 2009, 10:25 PM   #7
Cool! Never heard of this one! Not always THAT easy to determine a codec.
Old December 8th, 2009, 10:27 PM   #8
I've never had any luck with .mov files in Windows. Just have him render it to something more mainstream like mpeg2 (.mpg).
Joe Parker is offline   Reply With Quote
Old December 8th, 2009, 11:08 PM   #9
I'm sorry but this is AWFUL advice. MOV is a container. It says nothing about the compression scheme of the file contained inside. MPEG2 is a hugely lossy codec, even at high bitrates. The MOV container can contain lossless codecs and can work on windows just fine. I use them nearly exclusively because of the advanced codecs they support, like jpeg2000, DNxHD, the Blackmagic/AJA codecs, and others.
Old December 9th, 2009, 09:30 AM   #10
Sponsor: VASST
GSpot is one of those little tools that you wonder how you lived without once you try it. For AVI files it will even let you know if the codec is installed. For mov files it just lets you know what codec was used.
For mov files, you can also just open the file with the Quicktime player and use Ctrl+I to bring up the inspector windows where it will tell you what codec is being used.
~jr
Old December 9th, 2009, 09:38 AM   #11
~jr
This presumes that you can actually open the file in quicktime. This is not always true.
Old December 9th, 2009, 10:45 AM   #12
In his very first post, Ben did say that QuickTime couldn't open it :-(
Old December 9th, 2009, 11:04 AM   #13
Thanks for the clarification, even if it's a bit contradictory. I did not mean to imply that everyone has ridiculous amounts of trouble with .mov files in Windows. I only said I did.
However, you completely confuse any point you're trying to make by first claiming mpeg2 is (not "can be") a "hugely lossy codec", then pointing out that's what could actually be inside a mov file.
I stand by my advice. Why screw around with mov containers when it isn't necessary? The friend should be able to render a perfectly good mpg file, most of which won't even be re-rendered and thus will be original quality (assuming he knows what he's doing). There's no advantage at all to using a container like .mov , or the Windows container .avi.
Old December 9th, 2009, 11:38 AM   #14
However, you took your lone experience and extrapolated it as a cure-all for the OP. Regardless of whether that is a viable solution or not.
Mpeg2, by it's nature is lossy. At common bit rates available in most NLEs it is HUGELY lossy. Not can be, *IS*. I did not point out that Mpeg2 could be inside a .mov container. I said that an MOV container could house lossless (or nearly lossless) codecs. Mpeg2 is not one of them. Uncompressed is, Cineform is, DNxHD is, JP2K is, etc.
Why screw around with mov containers? Because that container currently is the most universal one with the best video codecs available. Period. Rendering an mpg regardless of container WILL be lossy. Not can, WILL. Why fool around with losing quality when its' totally unnecessary?
And how do you know what will or won't be re-rendered? This is unknowable without knowing what the native format of the video is. The camera that was used for the shoot was never mentioned.
Perrone Ford is offline   Reply
