32 bit and 64 bit on same 64bit OS? at DVinfo.net
Old November 17th, 2009, 09:26 PM   #1
Is it possible to run both the 32 bit and 64 bit 9.0c on a 64bit Vista home premium OS?
I ask as I tried installing the 32bit tonight and while it seems to run I've had it blow up on me a couple times for no reason...
Also the main reason I tried to install the 32 bit was so that I could run the Debugmode Frameserver - which while it shows up as a render option now in the 32 bit version I keep getting a message that no template exists and it won't let the frame server start...
Thanks for any advice!
Thomas Moore is offline   Reply With Quote
Old November 17th, 2009, 11:22 PM   #2
Many of us here, me included, have run 3 or 4 versions of Vegas on Vista without a hiccup.
Old November 18th, 2009, 06:29 AM   #3
hrm, OK what about the "no template" for the debug frame server?
Old November 18th, 2009, 09:39 AM   #4
Sorry, can't help with that, don't even know what it is!
Because of the title of you post, you may not get timely responses at this point. You might need to repost using Debug Frame Server in the title.
Old November 18th, 2009, 10:57 AM   #5
Good point!...
