Installed windows 7.. now Vegas can't save
Just installed Windows 7 64.. Have Vegas 9.0c 32-bit running on it..
Opened a project from my eSata drive.. but Vegas refuses to save the project file or save it as a new filename on the eSata drive. Spits out this error msg "An error occured while saving the project file xxx.veg. The file could not be created." However, if I save to a new drive like to my desktop, it saves it fine.. Any idea why? |
Vegas is not seeing the drive and/or the drive has issues. Run disc check on the drive.
make sure to check the "auto check errors" is checked when you do the disc check, though that should already be checked.
Ahh problem solved.. my admin user didn't have full rights to the drive.. so weird!
#5 |
Glad you found the issue.
