EX1 720p footage at DVinfo.net
Old November 15th, 2009, 09:13 AM   #1
EX1 720p footage
Hi All, I've just shot some 720/25p footage on the EX1. What should my project settings be?
The reason I ask is in vegas it doesn't seem to have a HD 720 25p setting?
I have Vegas 9.
Thanks in advance.
Joseph Kassana is offline   Reply With Quote
Old November 15th, 2009, 12:41 PM   #2
..I'm checking my Vegas 8 version and THERE is an HDV-720-25p template project that it is maybe what you need... donīt let the "HDV" name confuses you here... and remember that ALWAYS you can "customize" any template to whatever you want (dimensions, PAR, res. quality, etc) and then save it under any (new) name you want .....
good luck
Enrique Orozco - Sony/JVC/Nikon/Panny cams, DJI/Yuneec drones, VegasPro
www.aerofilm.com.mx
Enrique Orozco Robles is offline   Reply With Quote
Old November 15th, 2009, 12:48 PM   #3
Vegas will match your media with the closest setting, here's how to make that happen:
Open Vegas
go to File - Project properties and click to open Project Properties window
Do you see the first line, templates? go to the right of that all the way over and click on the folder icon and navigate to any one of the video clips you are going to edit; then click on it. Vegas should then select the correct template for you.
Old November 15th, 2009, 04:01 PM   #4
Thanks Guys.
