creating avchd disc at DVinfo.net
Old October 27th, 2009, 09:03 AM   #1
creating avchd disc
Hello.
I'm trying to create a disc which is the combo of hi-def video on a standard disc that will play on my Playstation 3, it's all I have for a blu-ray player at present, with menus as opposed to the data disc it's being recognized as right now.
I'm reading a bunch of things about it and I've confused myself a little.
First off, can I create the video files in Vegas and render this AVCHD disc format with DVDA?
Secondly, I read that I should be rendering the disc as AVCHD from Vegas. I know Vegas renders files, but does it render the entire disc with a menu? I didn't think it did.
Third, am I even on the right track here?
Rich
Rich Petruccelli is offline   Reply With Quote
Old October 27th, 2009, 08:26 PM   #2
Rich,
I don't know if this is going to help or not.
You state that you want to create HD on a standard DVD from AVCHD files. I do this by selecting WMV11 under the render as menu, then select the appropriate settings (ie. 6mbs 1080 30P) or whatever your property settings are.
After creating the WMV file, I insert a blank standard DVD into my PC and create a video DVD with the WMV file I just created.
I have but do not use the DVD Architect.
Hope this helps,
Doug
Doug Marcum is offline   Reply With Quote
Old October 28th, 2009, 06:09 AM   #3
Hey Doug. Thanks for the reply. Unfortunately it appears that DVDA doesn't accomplish this task at present time. I tried another authoring package and it worked. I don't like that you can't customize the menus like you can in DVDA, but for now... It works.
R
