Video Specs for PowerPoint? at DVinfo.net
Old October 8th, 2009, 09:59 AM   #1
I am preparing a powerpoint presentation that includes video. Any suggestions on what size the video should be, bitrate,and format?-Dont want it to fall apart when projected. I will be presenting from my Dell Laptop. I am bringing video INTO the powerpoint, not powerpoint into the video.
Vegas 8.0c (Build 260)-(Upgraded to Sony Vegas 10 pro)Canon GL2, Canon HV30, HF200, HF20-Sony UWP Wirelesss Mic Kit, Intel Core 2 CPU-6600@2.40GHz-3.00GB Ram
David Ruhland is offline   Reply With Quote
Old October 8th, 2009, 04:52 PM   #2
WMV works pretty darn well with ppt on a pc (mac is different!).
Size, well, it depends. In ppt you can resize video, or show it full screen. WM's resizing engine is pretty good. So, perhaps 320x240 for in a window, 640x480 for SD clips, or on up to screen resolution for full screen with HD clips.
Bitrates can be relatively high, since you're playing back from hard drive.
Here's some rates to try, but a lot depends on the content:
320x240 - 650Kbps
640x480 - 1800Kbps
1280x720 (720p) - 6Mbps
Old October 14th, 2009, 04:22 PM   #3
If you ever need to do the powerpoint presentation from another PC then you need to save the video clips also in the same folder as the ppt file. Otherwise when you come to the video slide only the first frame will get displayed.
Asvaldur Kristjansson is offline   Reply With Quote
Old October 14th, 2009, 04:26 PM   #4
As well, the filepath MUST remain under a certain number of characters (I BELIEVE it's something like 128) in order to be accessed. This isn't a big deal as long as it's being played locally - I once spent half a day troubleshooting a PowerPoint that wouldn't work because the .PPT was trying to call a movie on a network drive, a VERY long logical address.
http://office.microsoft.com/en-us/po...777161033.aspx
