Rendering out to m2v and then not able to edit it?!? at DVinfo.net
Old September 28th, 2009, 12:27 PM   #1
I had rendered out a movie m2v for DVD. After I had finished, I lost my original captured AVI. So at least I had the m2v to use and re-edit if necessary, but I was shocked to discover that I cannot edit the m2v file! Is this a problem with my system or do I need to download a certain codec to accomplish this process?
David Delaney is offline   Reply With Quote
Old September 28th, 2009, 12:50 PM   #2
Sponsor: JET DV
What happens if you rename it to MPG?
Old September 28th, 2009, 12:51 PM   #3
or as .m2t.
Chris J. Barcellos
Old September 28th, 2009, 01:15 PM   #4
I will try that...
Old September 28th, 2009, 02:29 PM   #5
It did not work - renaming them both m2t or mpg. It tells me the files are still corrupted, yet they are fine to play using MP and VLC and they work fine in Arch.
Using Vista
Old September 29th, 2009, 07:02 AM   #6
Sponsor: JET DV
You may need to mux an audio track with it for Vegas to see it. Or use some other program to convert it to a format Vegas can read.
Old September 30th, 2009, 02:34 PM   #7
Am I the only one that has this issue? Is it just my machine?
