Rendering Multiple Clips at DVinfo.net
Old September 24th, 2009, 11:25 AM   #1
I have a single project, about an hour and a half long, with about 30 chapter markers. I want to render each region separately to make them web ready, as <region name>.wmv (or the appropriate format). Sounds like a good job for scripting? I'm a C# developer at Microsoft, but to be honest, I haven't looked at Vegas scripting yet, maybe it's time! Does Excalibur or similar already have this built in, by chance?
Jeff
Jeff Dillon is offline   Reply With Quote
Old September 24th, 2009, 11:36 AM   #2
Sponsor: JET DV
Tools - scripting - Batch Render
Old September 24th, 2009, 11:38 AM   #3
It's already built into Vegas Pro 8.
Tools - Scripting - Batch Render.
The option to render regions comes up when you run the script.
Old September 24th, 2009, 11:57 AM   #4
Ah, got it. I just learned the difference between a Marker, and a Region. I have chapter markers placed, not regions. So, any script to create regions based on markers??
Old September 24th, 2009, 12:02 PM   #5
Sponsor: JET DV
Excalibur can convert the markers to regions for you.
Old September 24th, 2009, 12:26 PM   #6
If you don't have Excalibur and can't find a script to do this, double-click between each set of markers in the area just above the timeline and press R to create a region.
Old September 24th, 2009, 12:34 PM   #7
I knew I had one lying around on my hard drive somewhere :-)
Thanks to John Meyer for this script.
Copy everything below and save it as MarkersToRegions.js
* This script will convert markers to regions.
* The original markers are left intact.
* The script ignores all markers beyond the last event.
* By John Meyer 12/8/2003
import System;
import System.IO;
import System.Windows.Forms;
import Sony.Vegas;
var MyRegion : Region;
var PrevMarker : Marker;
var RegionStart : Timecode;
var RegionEnd : Timecode;
try {
var markerEnum = new Enumerator(Vegas.Project.Markers); // Start going through all the markers
PrevMarker = markerEnum.item(); // Remember first marker
while (!markerEnum.atEnd()) { // Keep going until last marker
markerEnum.moveNext(); // Get next marker
if (markerEnum.atEnd()) { // If no more markers (we're almost finished),
RegionEnd = Vegas.Project.Length; // get timecode at end of project
else {
RegionEnd = markerEnum.item().Position; // Get timecode for current marker
RegionStart = PrevMarker.Position; // Regions starts at previous marker.
var RegionName = PrevMarker.Label; // Name the region using previous marker's name.
// The RegionExist function checks if a region already exists at this point.
if (!RegionExist(RegionStart.ToMilliseconds(),RegionEnd.ToMilliseconds() ) ) {
MyRegion = new Region(RegionStart,RegionEnd - RegionStart,RegionName);
Vegas.Project.Regions.Add(MyRegion); // Add the new region
if (markerEnum.atEnd()) break; // If out of markers, quit.
// If last marker is equal to or beyond the end of the project, stop here.
if ( Vegas.Project.Length.ToMilliseconds() <= markerEnum.item().Position.ToMilliseconds() ) {
break;
else {
PrevMarker = markerEnum.item(); // Remember this marker for next loop.
} catch (e) {
MessageBox.Show(e);
function RegionExist(dStart,dLength) : boolean {
var fmarkerEnum = new Enumerator(Vegas.Project.Regions);
while (!fmarkerEnum.atEnd()) {
var fRegion = fmarkerEnum.item();
var fRegionLength = fRegion.Length.ToMilliseconds();
var fRegionStart = fRegion.Position.ToMilliseconds();
if ( (dLength == fRegionLength) && (dStart == fRegionStart) ) {
return 1;
fmarkerEnum.moveNext();
return 0;
Old September 27th, 2009, 08:48 AM   #8
Sponsor: VASST
I see Edward already answered for Excalibur but VASST Ultimate S Pro can not only convert the markers to regions but it can also do the batch rendering without the need to do the conversion at all. The batch renderer in Ultimate S Pro will render between Markers (as well as within Regions).
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline   Reply
