Workflow for quality at DVinfo.net
Old March 24th, 2005, 01:23 PM   #1
Iv captured all my vid and am dumping it into vegas. I need to then go to after effects for fine tuning. What codec should i use to get to after effects? avi im assuming. After im done with after effects is that were I should do the mpeg encoding for dvd? Im not worried about hardive space or time, just quality. Thanks!
Mark Errante is offline   Reply With Quote
Old March 24th, 2005, 01:44 PM   #2
Sponsor: JET DV
Use Uncompressed AVI
Old March 24th, 2005, 02:24 PM   #3
What is the uncompressed avi labled as? microsoft dv? Im totally new to vegas...well editing in general. thanks
Old March 24th, 2005, 03:25 PM   #4
Sponsor: JET DV
NO
When rendering in Vegas, choose AVI as the type and Default (Uncompressed) as the template. Uncompressed should be a separate setting in AE as well.
Old March 24th, 2005, 03:28 PM   #5
Old June 17th, 2005, 01:31 AM   #6
Is there a particular uncompressed AVI format that will save time ?
DV is YCrCb, right ? But does VEGAS do its internal processing (video effects) in YCrCb or RGB ?
Gints Klimanis is offline   Reply With Quote
Old June 17th, 2005, 03:25 AM   #7
RED Code Chef
There is only one uncompressed format. So pick uncompressed if it is listed
in the program. Otherwise choose "none" when you need to select a codec
(AVI is a file format, not the codec).
Rob Lohman, visuar@iname.com
Old June 24th, 2005, 03:08 PM   #8
That's a pretty good question.. if you want to do effects or compositing work after the fact, is it better to be using a YUV format or an RGB format (in After Effects for example)?
PAL shooter in NTSC territory
Patrick Jenkins is offline   Reply With Quote
Old June 29th, 2005, 09:33 AM   #9
Lossless DV Codec
Try this codec. Saves a bit more space over uncompressed and is lossless in terms of quality.
http://www.alparysoft.com/products.php?id=8&item=35
Don't know if there are any issues with AE, but I've used it flawlessly with Combustion 4
Declan Smith is offline   Reply With Quote
Old July 2nd, 2005, 07:25 AM   #10
Huffyyuv 2.1c works well for .avi stuff, microcosm for quicktime is 64 bit lossless.
Canon C100, 5D3
Jeff Baker is offline   Reply
