Export files as native DV format? at DVinfo.net
Old March 22nd, 2005, 01:22 PM   #1
Can you export from Vegas timeline or from individual clip as native DV file?
Jeff
Jeff Bradt is offline   Reply With Quote
Old March 22nd, 2005, 01:58 PM   #2
Yes. "Render As> DV AVI"
Glen Elliott is offline   Reply With Quote
Old March 22nd, 2005, 02:17 PM   #3
I'll need to write out files more than 2gb (the limit for avi).
Jeff
Old March 22nd, 2005, 02:54 PM   #4
2 gigs isn't an AVI limit it's an OS file size limit. You have to change your drives to NTFS...your probably running FAT32. With NTFS I believe the file size limit will be 15gigs.
Old March 22nd, 2005, 03:22 PM   #5
I've been doing some reading....it looks like 2gig is the limit for AVI but AVI2 (which Vegas can handle) doesn't have the 2gig limit. Does that sound right?
Jeff
Old March 22nd, 2005, 03:47 PM   #6
Sponsor: JET DV
Yes. The first version of AVI had a 2Gig filesize limit. (Of course the OS had a 2Gig filesize limit as well at the time - FAT). Then came along FAT32 which upped the file size limit to 4 Gig and NTFS which upped the limit to a few terrabytes (or something like that). AVI Type 2 no longer has that file size limit which is what Vegas uses by default. I routinely have 13+ Gig files.
Old March 22nd, 2005, 04:22 PM   #7
Hey thanks Glen and Ed. I'm trying to find a tapeless way to share video with my partner who will be editing in Avid. Looks like this will work. - Jeff
Jeff
Old March 22nd, 2005, 04:55 PM   #8
The EASIEST solution would be to convert this "Avid" guy to Vegas. Then you could share your .VEG files. *hint hint*
Old March 22nd, 2005, 05:31 PM   #9
Sounds like a plan!
Jeff
Old March 22nd, 2005, 09:27 PM   #10
Ed, under General Preferences, do I need to check "Strictly conform to AVI2 specifications"? Thanks.
Jeff
Old March 22nd, 2005, 11:36 PM   #11
Sponsor: JET DV
No.
Strictly confirm to AVI2 - unchecked
Use Microsoft DV - unchecked
Ignore 3rd party codecs - CHECKED
These are the default settings.
Edward Troxel is offline   Reply
