Vegas Video discussions from 2006 (Q3Q4) - Page 98 at DVinfo.net
Old November 22nd, 2006, 08:55 PM   #1456
Sponsor: JET DV
You could always hold down CTRL-SHIFT when starting Vegas to reset it back to factory defaults.
Edward Troxel is offline
Old November 22nd, 2006, 09:20 PM   #1457
Any ideas anyone?
Eugene Kong is offline
Old November 22nd, 2006, 10:01 PM   #1458
No idea. I'm dealing with my own exception error in Vegas, and no one has been able to help me including Sony.
Will Hanlon is offline
Old November 22nd, 2006, 10:36 PM   #1459
DVDA Disc Space Used Message
Hey guys,
Everytime I try to bring a mpg 2 file into DVDA 4 it says that the disc space used is 8.1 GB (Which is extremely large.) I opened this same file in DVDA 2 and it says disc space used 4.4 GB. I just completed two DVD projects in DVDA 2 because of this issue. What could be the problem? Is there a setting that I need to change in DVDA 4?
Thanks.
Jack-of-all-trades trying to master one (Videography)
www.sdfvideo.com
Albert Rodgers is offline
Old November 23rd, 2006, 02:18 AM   #1460
Vegas 7 using quad cores?
I believe Vegas 7 utilizes Core 2 (and other dual cores) to their potential, but the new Intel quad core (QX6700) is essentially two Core 2 E6700 together. Will Vegas be able to use the four cores to their potential? Will Vegas be able to use AMD's 4x4 to its potential when it comes out?
Alex Thames is offline
Old November 23rd, 2006, 03:08 AM   #1461
Apparently there's support as these tests indicate http://www.hothardware.com/viewartic...leid=878&cid=1 ... PC and CPU testers should use Sony Vegas more often to benchmark new equipment...
High-Definition Video Consultant - CEO of Delimex NV - http://www.delimex.be
gear of choice : http://www.wespgear.com
Werner Wesp is offline
Old November 23rd, 2006, 07:05 AM   #1462
Forget what DVDA says about file size. It is not only very conservative but often so far off it's pathetic. Look at the file size in the EXPLORER WINDOW. It will tell you exactly how big the file is. I never look at the file size as it's read out by DVDA-this IMO is the one thing I wish they would do something about soon.
Don
Don Bloom is offline
Old November 23rd, 2006, 07:59 AM   #1463
Images: 10
http://www.vasst.com/resource.aspx?i...c-a7f431ebd02d
Bill Ravens is offline
Old November 23rd, 2006, 08:54 AM   #1464
Yeah, I do have that set right. It's just the matter of being able to skip, using the remote, from the last chapter of clip 1 to the first chapter of clip 2.
Ryan Laytart is offline
Old November 23rd, 2006, 06:35 PM   #1465
Okay, it seems that the footage when capturing is registering as 50fps for some reason, rather than 25fps. Found this out by capturing some footage in CapDVHS. So it may be the way it was shot, rather than the settings in Vegas.
PJ Gallagher is offline
Old November 23rd, 2006, 06:46 PM   #1466
This is a actually something I've been wondering about myself. I know you can assign an affect to a whole track or the output of all tracks....but is there a way to apply in one action an effect to multiple clips....so that each clip has the effect applied, but you can still adjust each one individually.
I know you could key frame an effect over a whole track need be, but I prefer when say doing colour correction and brightness/contrast control, to put those on each clip then adjust them individually. This task would be made a little bit easier if I didnt have to add the effects to each clip.
Lee Kennedy is offline
Old November 23rd, 2006, 06:55 PM   #1467
COPY>Paste Attributes
Highlite the clips you want the effect on and paste it to those then you can go back in and individually adjust but to me it seems if you're going to do that you might as well save it as a preset and then place it on the clip 1 at a time and adjust to taste.
Don
Old November 23rd, 2006, 09:46 PM   #1468
screen problem
ok when i view effects in vegas it comes up as the image below, it cuts off after the size of the default box, anyone else have this problem or how to fix it thanks.
http://i72.photobucket.com/albums/i1...ewupscreen.jpg
Jacob Eirckson is offline
Old November 24th, 2006, 08:25 AM   #1469
Seth,
Check my article "Video De-interlacing with Vegas" here:
http://michael-morlan.net/pages/lear...nterlacing.htm
Enjoy,
Michael
Michael Morlan . cinematographer | local 600 operator
http://michael-morlan.net . http://talltalepictures.com
Michael Morlan is offline
Old November 24th, 2006, 10:07 AM   #1470
Sponsor: JET DV
That's a new one for me. What if you close and then re-open that window? What if you reduce acceleration on the video card?
