Vegas Video discussions from 2006 (Q3Q4) - Page 92 at DVinfo.net
Old November 15th, 2006, 04:52 PM   #1366
Trying adding the effect at the track level. Third icon from the left.
Jim Montgomery is offline
Old November 15th, 2006, 09:02 PM   #1367
Thank you Emre and Simon for pointing this out. I am going to try this out - looks like it will save me hours of work!
Nature Boy
Phil French is offline
Old November 15th, 2006, 09:31 PM   #1368
Movie Scene on Yahoo Talent Show
Fellow Vegans,
I posted some scenes from my film "Catch A Rising Bullet" online at the Yahoo Talent show.
http://tinyurl.com/yhtqwv
This production exists only because of Vegas (having started with Vegas 4).
Comments, thoughts, and even flames are appreciated.
The film has been in post since Vegas 5, and will be finished in Vegas 6. The audio is still rough, but I couldn't resist taking advantage of Yahoo's generosity. Running time will exceed two hours, yet maintain a brisk pace.
Has anyone else entered?
BMW
Brian Mitchell Warshawsky is offline
Old November 15th, 2006, 10:32 PM   #1369
Drag the effect into the preview window for video and the master volume for audio
Jim Ohair is offline
Old November 16th, 2006, 03:19 PM   #1370
Help: I can't get the 2nd video track to show up
AND, It's time to figure this out. I have been needing to finish simple projects, so I have just put all of my video on one track and trimmed them appropriately.
Now I am ready to be a grown-up about it and use my composite envelopes etc.
I'm sure it is something bonehead that I just haven't been able to figure out., probably a button to press. I have spent about 3 hours experimenting, reading the manual and Eagle's Vegas book, to no avail.
To be clear, my envelopes work fine. I can get the top video track to fade out in color or composite. I can also just use the level fader in the control strip to the left. The challenge is that the video tracks directly beneath it do not become visibile when the top track get transparent. the screen/preview window/rendered file just goes black the more transparent, the more black shows through).
Help!
Mark
Mark Lewis is offline
Old November 16th, 2006, 03:24 PM   #1371
most obvious first:
Is the track enabled for viewing? I can't remember the icon (is it the "!"), but if it is selected, you won't see or hear what's on a particular track.
Even if it is enabled, to you have transparency set to 100% ? That would also make it invisible.
Chris J. Barcellos
Chris Barcellos is offline
Old November 16th, 2006, 03:26 PM   #1372
partially fixed - slightly different question now
Of course, as soon as I hit send, I noticed that the top track was further left than the other tracks by a quarter inch.
I added a new video track, moved my clips to it, and it works fine.
Somehow, I don't know how, I have tracks in my project that look like video tracks, but don't show up. They have a quarter inch space to the left of the track controlsjust left of the minimize/maximize buttons.
Does anyone know what these are, what they are for, and/or how to convert them to normal tracks? For now, I will just move the clips on them to "working" tracks...
mARK
Old November 16th, 2006, 04:10 PM   #1373
kind of sounds like you have PARENT/CHILD set up on the tracks. I could be wrong but there's nothing else that I know of that sounds like what you have described. If you don't need P/C then release it by clicking on the up arrow of the bottom track.
Don
Don Bloom is offline
Old November 16th, 2006, 04:29 PM   #1374
Thanks for the responses guys.
Another couple of questions:
I have now installed DVD Architect. It seems that I have to render the MPEG and audio files, then as a separate action set up your DVD menus and burn/author. Does this sound right?
Also, is it possible to "burn" the project to the hard drive? In other words, can Vegas MS/Vegas full create the VIDEO TS folder on a hard drive without actually putting it onto a DVD ?
Alwyn Adkins is offline
Old November 16th, 2006, 06:25 PM   #1375
moving files properly ?
i recently got a new laptop, i'm trying to open up an old project i have, i moved all the media fine but everytime i open the veg the damn thing still links it to my old pc locations and i have to specify the files again each time? even though i hit save it still doesn't remember the new locations, how can i do this?
thanks
Pete Peterson is offline
Old November 16th, 2006, 06:32 PM   #1376
It should remember once you save, but the correct way is to move using the Project Media tab.
Emre Safak is offline
Old November 16th, 2006, 07:57 PM   #1377
Sponsor: JET DV
You can do that. Just render the video to MPEG2 (adjusting the bitrate as appropriate) and the audio as AC-3 and then give DVD Architect both of those files. Alternately, you could render to DV-AVI and let DVD Architect do the conversions for you.
Yes it is. That's what the "Prepare" process does - create a folder containing the Video_TS and Audio_TS folders. You can then burn that as many times as desired.
Edward Troxel is offline
Old November 16th, 2006, 10:05 PM   #1378
SoundForge 8.0d bug
Has anyone else noticed that Soundforge saves user data in the wrong place? It should be under %USERNAME%\Local Settings\Application Data\Sony\Sound Forge, but some programmer omitted a backslash so it became %USERNAME%\Local Settings\Application DataSony\Sound Forge instead! No biggie but it caught my attention when I was re-installing another application.
Old November 17th, 2006, 01:00 AM   #1379
Deinterlacing secrets?
I'm creating a short promo from HDV 1080i footage - just about got the edit done. The destination formats are various for google video, yahoo video and youtube.
The one thing I think they all have in common is that they'll do better with progressive, 30p.
I think my next step is to render the 1080/60i timeline to a 1080/30p cineform or sony yuv to serve as my digital master for all these renders to other destination formats.
Will setting up the project properties for progressive influence what's rendered, or, is that just determining display within Vegas?
Or, is the proper approach to specify "progressive scan" in the field order drop down in custom render setings?
Or is there another approach? The help file and manual are no help...
Tools - I have what comes with Vegas, I don't have Connect HD.
Seth Bloombaum is offline
Old November 17th, 2006, 03:46 AM   #1380
Moving soundtrack
Hi.
Is it possible to "unlock snapping" to a soundtrack in Vegas 7? I want to move the music a half frame to exactly match the beats to the frames.
Howe can this be done?
Arnt Mollan
www.mollanmedia.com
Arnt Mollan is offline
