Vegas Video discussions from 2006 (Q3Q4) - Page 45 at DVinfo.net
Old September 6th, 2006, 08:37 PM   #661
5 minutes = 300 seconds
100 MB = 800 Mb (8 bits per byte)
800/300 = 2.667 Mbps
Guy Bruner is offline
Old September 6th, 2006, 11:03 PM   #662
Thanks Guy.
C100, 5DMk2, FCPX
Ken Diewert is offline
Old September 7th, 2006, 02:33 AM   #663
Here is the simple calculator I use
http://www.videohelp.com/calc.htm
Vegas could provide an estimate of file size - doesn't matter if it is variable rate; for variable rate you specify an average rate, and that can be used in the calculation. It would need to do the same for the audio (as generally these are rendered separately). But it doesn't....
Mark Bryant is offline
Old September 7th, 2006, 07:02 AM   #664
Sponsor: VASST
Originally Posted by Ian Briscoe
I'm not sure which version is actually correct.
Since the pixel aspect ratios are different the clips will never match full frame. What you need to do is open Event Pan/Crop on the M2T file, Right-click on the frame and select Match Output Aspect. This will crop out the black so that the HDV footage matches the PAL DV Widescreen project aspect.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline
Old September 7th, 2006, 09:07 AM   #665
Oh. Oops. I misread the original post and then misunderstood the question. John's right.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline
Old September 7th, 2006, 09:08 AM   #666
Thanks, Mark. That calculator will be very handy.
-->jarrod whaley.
Old September 7th, 2006, 09:29 AM   #667
Scene Detection Problem
Vegas 6, Scene Detection Box Checked, sometimes gives me 2 or three files (out of many record start stops on the tape), generally doesnt. In v5 it sould give me a seperate scene for each time record was started and stopped. I'd like 6 to do the same. Any ideas? Thanks!
Kevin James is offline
Old September 7th, 2006, 10:18 AM   #668
Sponsor: JET DV
Is the clock set in the camera? Scenes are detected via jumps in the date/time code. If the clock is not set, scene detection will not work.
Edward Troxel is offline
Old September 7th, 2006, 10:30 AM   #669
Brian, have you tried SynthEyes?
If not here is the link to their main page.
http://www.ssontech.com/
Boycott Guinness, bring back the pint!!!
Joe Carney is offline
Old September 7th, 2006, 11:06 AM   #670
The clock was not set, thanks for the great information (again)!!
Old September 7th, 2006, 02:53 PM   #671
Overclock, Borders on composite
Two more questions for today =)
The first, is there a way to get more than 300% velocity on video?
The second (I have done this before, but it was two years ago and have since forgotten) is how do I put a border around a track I have reduced in size?
Thanks guys!
Old September 7th, 2006, 03:21 PM   #672
Sponsor: JET DV
1) Yes there is. Also set the playback rate (i.e. hold down the CTRL key and resize the event smaller) and you can get up to 12x.
2) Look to the left of the word "Border" for the small triangle. Click it. (It's the "pre/post" flag).
Old September 7th, 2006, 04:52 PM   #673
Edward, is this check box in the pan/crop menu?
Old September 7th, 2006, 05:16 PM   #674
Edward's probably having dinner so I'll take a shot at it.
Apply the Border FX and then look for that triangle.
It makes a major difference to the FX which way it faces.
Mike Kujbida is offline
Old September 7th, 2006, 05:26 PM   #675
Ahhhh, I have to add an effect....I'll check that out after this prerender finishes
