Vegas Video discussions from 2006 (Q3Q4) - Page 24 at DVinfo.net
Old July 26th, 2006, 08:20 AM   #346
Sponsor: JET DV
JKL simply is jumping greater distances on the timeline - it's not CHANGING the timeline. Velocity Envelope and Playback Rate both change the timeline.
Edward Troxel is offline
Old July 26th, 2006, 09:47 AM   #347
Simple Intra-Event Effects Question
I apologize for an easy one. Help files were unhelpful.
If I want to apply an effect to a portion of an event (e.g., 5 seconds of a 20 second video clip), is there an easy way to select that portion of the event I wish to change and apply the effect without (a) having to slice at the edges of the 5 second portion to creat a mini-event, or (b) apply key frames to hold the other, noneffected portions constant?
Stuart Dawkins is offline
Old July 26th, 2006, 09:56 AM   #348
No, those are the two methods Vegas provides.
Are you having issues with these methods? If so, perhaps there are some workflow suggestions forum contributors could provide.
For example, applying the same efx to a series of clips by moving them to a dedicated track and using track-level efx, or copy and paste attributes... depending on what it is you need to do.
Seth Bloombaum is offline
Old July 26th, 2006, 09:59 AM   #349
I appreciate the reply. I'm not having trouble so much as getting used to keyframing in Vegas. I'm an After Effects guy and Vegas has a different feel in this regard. Just wanted to make sure I wasn't missing something obvious. Thanks again.
Old July 26th, 2006, 11:03 AM   #350
Thanks Edward, I knew there was probably a logical reason... just wasn't sure what it was... still seems like for preview purposes it could be told to basically do the same ;) but maybe it is trying but has to read the instructions to do so every time which slows it all down.
OT: I just monitored my HD Read Bytes/Sec and even with 5 full DV tracks running with audio (yes it was a concophony but just testing) I was only seeing about 4MB/Sec being read.... is that correct? if that is the case then HD raids seem way less important than cpu power and we have a long way to go before worring about HD speed and transfer before cpu.
Kevin Richard is offline
Old July 26th, 2006, 11:17 AM   #351
I normally just split it with "s" and then apply it.. you can always group the files together after that and they will act as one again... don't think that applys to efx after that.. good question ... anyone?
Old July 27th, 2006, 09:44 AM   #352
Soft white glow effect ?
Looking to get a soft white glow transition effect between a couple of clips.
Not sure how to achieve it
Cheers
SC
Steve Clee is offline
Old July 27th, 2006, 10:34 AM   #353
I think Vegas has a preset that might give you what you're looking for... do you have any examples or anything of what you're trying to achieve?
Logan Bright is offline
Old July 27th, 2006, 11:59 AM   #354
Vegas has a soft glow transition preset, you could also split the ends of the clips and keyframe in the glow filter, blasting it all out at the tail and head of the two events.
I often mix glow with Negative/invert filters for a nice, although somewhat common effect.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old July 27th, 2006, 12:01 PM   #355
I'll give that a try.
SC
Old July 27th, 2006, 02:42 PM   #356
Tapeless, DVD Edit with Vegas
I shoot some projects straight to hard-drive in an HDD-DVD deck, it encodes to MPEG2 directly. Usually I just need to burn a DVD with the deck and that's it. However, occassinally I need to edit some stuff out, basic straight cuts. What I've been doing is ripping the DVD's into a single Vob and dropping into vegas, edit, re-render and burn with Architect. This is fine, but my question is, when 're-rendering' this Vob, is there any kind of 'generational' loss? Not that it really matters, just curious.
However, I'm trying to think of ways to speed things up, especially if I have to edit an all day job that is equivilant of 4 dvd's for next day delivery....the rendering time is killing me. I've thought of multiple computers, but that could get pricey. I thought of batch encoding all the vobs into Mpeg2 right away as I usually have a few days or weeks before the call comes in to edit....I thought if I already have Mpeg2 (instead of a Vob) I can edit that in Vegas,..but then I've got to re-render as mpeg2 to get it into Architect?? Does Vegas6 have like a smart-encode, where it knows the file is already an mpeg2 and will render very quickly compared to an avi or vob?
If anyone has any suggestions or experience with this it would be appreciated. Thx Mike
Mike McKay is offline
Old July 27th, 2006, 02:50 PM   #357
Yes, there is generational loss. If you're doing cuts-only work with the MPEG files, try Womble or other MPEG editing app. Vegas will always recompress MPEG files at this point in time.
Old July 27th, 2006, 07:54 PM   #358
Adding effects to target areas
I do the same thing. I either slpit the event or clip where the intention is or keyframe it.
John Lorince
Http://capturemotion.tv
John Lorince is offline
Old July 28th, 2006, 12:23 AM   #359
Connecting Clips in VMS Platinum
When I capture a DV tape, the VMSP capture program splits them up into smaller file chunks, and that is OK, especially when one needs to use the trimmer on some of them.
When I put the video clips together in the timeline of VMS Platinum, I move them visually with the mouse, expanding the timeline to make sure no gap exists between them, and most times its OK.
But I am relying on my eyesight and raw mouse movements to achieve this. Is there a keypress combo that butts a pasted video clip to the tail of the previous video clip with no gap?
If there is no keystroke and I do it visually, should I go for 'Half diamond' or 'triangle' when putting them together? Thin vertical line or thick one?
Thanks for any advice.
David Errington is offline
Old July 28th, 2006, 07:12 AM   #360
Sponsor: JET DV
Options - Preferences - Turn OFF "Scene Detection"
The clips should "snap" together (assuming you haven't turned off snapping). You can always zoom in on the timeline to confirm, though.
