Vegas Video discussions from 2006 (Q3Q4) - Page 108 at DVinfo.net
Old December 6th, 2006, 02:36 AM   #1606
Old Boot
Glenn, thanks for the samples. I have them open and again have learnt loads just from this VEG.
Many thanks - G
Graham Bernard is offline
Old December 6th, 2006, 05:50 AM   #1607
Removing halos
I recently shot some SD video of penguins in Antarctica. In a few of the shots there are somewhat objectionable halos around the subjects, I presume from in-camera sharpening, and I would like to try and reduce these artifacts. I use Vegas 5.
I have tried using light blur and negative USM, but the image is too soft by the time the halos are significantly reduced.
Does anybody know if there is a different way to deal with this problem, such as a third party plug-in? I couldn't find anything using search.
Many thanks
Duncan
Duncan Wilson is offline
Old December 6th, 2006, 06:01 AM   #1608
Thanks guys!
That helped me alot! In the drop down lists you refer to several both in Vegas 7 and DVDA would it be too much to ask the exact options to select. optimally I will want to shoot in HD for future use. But for now I would like to Shoot in HD and down convert to SD. What options in the dropdown lists i.e. step 1 Vegas to Step .X. DVDA. Keep in mind that I also need to make a master to send to the replicator. So there might have to be two different procedures...I don't know. Thanks again. I know it takes time to respond and write at least it does me. So thanks for taking the time to respond to this rudemantary post. I am an old 'hunt and peck" typist. I will check out Spots Vegas editing also.
Thanks John
John Huling is offline
Old December 6th, 2006, 06:54 AM   #1609
Photoshopping large numbers of frames in a row?
I realize Vegas is very powerful and can create some awesome looks by using Levels and the other native color correcting tools. However, I find that in Photoshop, because I can use blending between layers and so on, that I can create more of the look I'm going for.
Question: Is there a way I can extract large numbers of frames from my footage (.AVI's) and convert them to numbered stills for batch processing in photoshop, then convert them back into .AVI?
(I searched and found similar answers but nothing about large quantities of frames, nor about re-importing them all automatically.)
Bill Porter is offline
Old December 6th, 2006, 08:21 AM   #1610
take the clip you want to do in PS (either split it to make it a seperate clip OR highlight the REGION) and goto TOOLS>SCRIPTING>RENDER AS IMAGE SEQUENCE.
That will make each frame a still that you can now bring into PS do your thing and then save them as the same name but perhaps put an A or something to differentiate from the originals. Keep them in sequence and then when your're ready go back to Vegas and goto FILE>IMPORT MEDIA and point to the image sequence you have. It will then come back into Vegas in the proper order and play out properly. Of course you need to set the time length of the stills in your preferences, if it's set to say 5 seconds it's going to be a very long non moving clip ;-)
HTHs
Don
Don Bloom is offline
Old December 6th, 2006, 08:53 AM   #1611
Sponsor: JET DV
If you import using the Image Sequence option, it will import correctly regardless of what the preference length says. Image Sequence brings them in as one frame per image.
Edward Troxel is offline
Old December 6th, 2006, 09:56 AM   #1612
John - how much editing are you doing for this material, what type of content is it (in general, eg sports, etc), and how are you getting it to the replicator, DVD or tape?
Dave Stern is offline
Old December 6th, 2006, 12:55 PM   #1613
You can try:
First do a light blur or some other 1-pixel blur to get rid of the halos. i.e. in the convolution kernel, put in 0.5 1 and 0.5 for the middle three values (horizontally). Vary the middle value (1) until you like what you see- it should be 1 or greater. If the camera applies some sort of bigger 2-pixel blur, then try the gaussian blur (horizontal only). Most cameras only sharpen horizontally; interlaced cameras tend to blur vertically.
After that, apply unsharp mask with a somewhat high radius. This should increase perceived sharpness.
Glenn Chan is offline
Old December 6th, 2006, 12:57 PM   #1614
Adobe After Effects is Photoshop-like and I find that it renders much faster.
2- Vegas also has many of Photoshop's blending layers.
Old December 6th, 2006, 01:40 PM   #1615
Originally Posted by Edward Troxel
For speed changes, either hold down the CTRL key and resize the clip or use a Velocity Envelope.
Let me rephrase that Im a newbie!
Tony Jucin is offline
Old December 6th, 2006, 01:44 PM   #1616
Glenn
Many thanks for the detailed response - I will try what you suggest.
Duncan
Old December 6th, 2006, 02:35 PM   #1617
Originally Posted by Plamen Petrov
Yes, of course, it is little faster, but not better result than Furnace. Shuttering and strobing still remain.
Vegas was not designed for post-production tasks like this; for that you still need After Effects. I have not got nice results from Vegas' motion blur capability either.
Emre Safak is offline
Old December 6th, 2006, 03:34 PM   #1618
Sponsor: JET DV
Ok, look at Vol 1 #9 of my newsletters for the article "Change the Speed of a Clip". You might want to look over the other newsletters while you're there as well.
Old December 6th, 2006, 04:11 PM   #1619
Dave
I have not decided or been told yet. I believe it has to be delivered on Tape. It will go to a "post/production house" from me so I am not sure. I will shooting again Saturday. I tried the slowmo on vegas7 contl drag worked just fine. Close up of piano playing fingers in slow mo is very interesting to me anyway. Might be like watching paint dry for others!
Old December 6th, 2006, 04:56 PM   #1620
How can Threshold and Black Restore help? I'm very confused on how to use them. I looked at them, applied them, but I'm not smart enough to know how to use them. Any tips on techniques with them? Thanks.
Will Hanlon is offline
