#1276 |
3D in Vegas
Good day gents...
I have a transparent cutout of a person (overlay) in a video track and below this track is located a video track with an image of NYC used as background. In this topmost track are located other transparent cutouts that appear and dissappear during the photo montage. The project is for all intents finished. However, for giggles I am attempting to create a slight 3d effect with a couple of the figures because I am at the beginning of my learning how to use 3d in Vegas and thought I would try somthing simple.... I am finding though that unlike the Pan and Crop feature, when I activate TRACKMOTION it is turned on for the entire track, not just for the photo or video clip I am working on. I don't "get" why the whole video track must be included in the 3D workspace time line... What am I missing...I was up all night trying to understand this...thanks Jeff Harper |
#1277 |
Sponsor: JET DV
As you have seen, "Track" Motion affects the entire track. Pan/Crop works with individual events. However, the 3D tools are only available in Track Motion so it's either an "all or nothing" thing. The bad part is that as soon as you turn on 3D in the Track Motion, it will slow down the rendering for the entire project.
I question exactly what you're trying to do. If you just want the "cut out" to get closer to the camera, for example, Pan/Crop would do it fine. Exactly what parts of the 3D are you planning on using?
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#1278 |
I have the HDR-HC1 and my computer wouldn't recognize my camera either. I installed SP2 and it's been working ever since.
Mark |
#1279 |
Countdown
Does anyone know either 1) where I can download a generic countdown or 2) a simple way to make one within Vegas (version 5)? The countdown needs to be about 5 minutes long. Any help would be greatly appreciated.
#1280 |
Sponsor: JET DV
There are a few on the VASST website and they currently have a contest going on so there should be more countdowns available soon.
http://www.vasst.com/search.aspx?text=countdown http://www.vasst.com/contest.aspx?id...b-ae8c3dc2d430 Beyond that: http://www.archive.org/movies/movies...ader01&from=BA http://www.fotosearch.com/video-footage/leader.html http://www.artbeats.com/prod/search....leader&ct=&fm=
#1281 |
Jeff,
As with all the Track motion, FX, etc, you can isolate the settings for a particular part of the track by using keyframes. In some instances it's easiest to just create a different track for each effect. Gary |
#1282 |
White Letterbox??
I am trying to create a white letterbox around my video instead of the standard black letterbox.
Any idea how to do this? I usually just bring in a photoshop mask to letterbox my video, but now matter what I do the masked out area always appears black. Any way to make it appear white?
Toogood Studios |
#1283 |
Edward,
I wanted to zoom in on a cutout and to make it appear the "camera" is coming around at an angle...I As I mentioned, the project is done, and the client is extremely happy with what they have seen...but I had extra time to spend on it and wanted to play with the 3d features... Gary, I know what you mean about the keyframe, but the timeline in the 3d workspace includes the entire project, just as Edward mentioned...I can't select the photo I want to (in this case) angle one way or the other away from the front to give it a touch of added dimensions. I have to select the whole track for 3d, which makes the tiniest move in the keyframer move the effect 10 mins down the timeline instead of just a little further along that photo or video clip. So if I have an 3d effect that I wish to use on a 2 to 5 second photo, the timeline in the 3d keyframer doesn't represent the length of time of the photo but instead represents the entire length of the project. My plan is to learn 3d compositing because I plan to use it a lot in the future on almost all stillmotion projects...I want to use the 3d effect for things like routine creation of things like a video begin to play within a picture frame within a photo, etc...you guys know what I mean... Do I just need a dedicated 3d program? Until then, would you suggest I create a scene as a separate project, and then import the veg file into the main project? Thanks for your input... |
#1284 |
Put the white file down as a layer underneath your main layer and crop your main layer. Should work fine in any program.
KW |
#1285 |
HDV to SD 704x480
I find that if I render HDV to SD 720x480, I either have black "pillarbox" areas on either side of the frame, or I have to crop a little off the top and bottom off the image in order to have the image fill the frame. I can also stretch the image to fit, but I hate changing the aspect ratio even that small bit (though I doubt anyone would notice). On the other hand, an HDV to SD render to 704x480 mpeg 2 is the same shape and requires no extra scaling or stretching. For now this seems to be the way to go. Is there any reason I sould avoid 704x480 for HDV to SD renders?
#1286 |
Yeah...I'm aware. Thaz why I was wondering if there is any other new tech that can counter that.Anyway,I'll work on a nice & affordable product instead..thanks
#1287 |
Sony Loops
I supposedly have a collection of Sony Loops that come with Vegas Video 6 but for the life of me can't figure out how to use them or access them.
The file I have is... Sony_Sound_Series_Loops_and_Samples.en-US.medialib-bak and is 319MB in size. I have looked at the manual and done as much as I can think of. I still can't access them. Since all the smart people are on this website I would appreciate your help. I need to have some background music for a project we are doing. Thanks, Tery |
#1288 | |
-gb- |
#1289 |
That was easy!
Thanks, sometimes I think I try and make things harder than they need to be.
Toogood Studios |
#1290 |
Jeff,
If you just put the particular photo you're working on (needing 3d track motion) on a seperate track you can key frame it to your hearts desire manipulate the heck out of it and not affect any other part of the project. I do that frequently. Don |
