#1201 |
Sponsor: JET DV
There's an extremely good chance that they can simply play the NTSC DVDs. You might want to check with them on that.
As a stop-gap measure, you might try rendering to a full PAL DV-AVI file and then give that to DVDA.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#1202 |
Will Vegas import a targa sequence?
Hello to all:
I'm not a Vegas user as such but I need to prepare some material for a client who is. I have two questions: 1) Will Vegas import a targa sequence and work with it on the timeline along with existing HD material? 2) Does Vegas work with all HD resolutions (1920 X 1080I, 1280 x 720P)? Thanks, George
"the difference between an amateur photographer and a professional is the amateur shows you all his pictures" |
#1203 |
Sponsor: JET DV
1) Yes. Just to a file - import, pick the first file, and check the box indicating this is an image sequence.
2) Yes. Both of those are supported.
#1204 | |
One thing you may want to be aware of George, in most instances TGA sequences are square pixel, and therefore will probably need to be matched ot aspect ratio using the Pan/Crop tool. If you're working with most HD formats in the 1080 flavor, like HDV they're not square like 1920 is, they have an aspect of 1.333, so set your targa sequences to 1440 x 1080 rather than 1920 x 1080.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#1205 |
Thank you Edward. I appreciate the input.
I'm nervous to be sending out NTSC versions for the cost of shipping. This is a fundraiser for a non-profit, so every dollar i can keep benefits them more. However, i'm getting to the frustration point here where i think i just might send out some NTSC copies and hope for the best. Our "audience" can barely tell me the make of their DVD player, let alone what their setup is capable of playing. ;) I didn't think of the straight DV-AVI. I tried rendering the video and audio together as a single mpeg with 2 tracks (not seperate streams for DVDA as i've always done for best quality) and i think the audio is STILL off. Of course, i'm checking this all on a computer since i have no PAL setup, but they do seem to be off. Maybe i'll try the DV-AVI re-render, and if that doesn't work, i'll just ship out some NTSC versions and cross my fingers. If i have to re-ship, so be it. Thank you again. kind regards, matt lewis |
#1206 |
Thanks to both of you for for the replies...
Douglas: Does that go for 720P as well? George
#1207 |
720p is a square pixel format. 1920 x 1080 is a square pixel format. Anything in the MPEG 1080 realm is non-square, including the broadcast streams for 1080.
#1208 |
Good information.
Thanks again, Douglas!
#1209 |
Vegas 6 nesting
I was reading "what's new in Vegas 6" and saw that you can drop .veg files right into a new track.
Looks like I will have to migrate to Vegas 6 Mike |
#1210 |
My must-have additions to Vegas are DVDLab Pro for authoring and Procoder for encoding (and debugmode's wonderful frameserver for sending the Vegas output to Procoder). I also sometimes do stuff in Photoshop and import the .psd's into DVDLab Pro.
#1211 |
My Ikegami DV7w won't rec to tape through firewire, either. I use a Sony DSR20 to loop into the NLE. The Sony DSR11 is a low cost deck that is very well made.
John Hartney Elgin, Illinois USA 847.742.9321 |
#1212 |
Vegas Gurus !
Hi everyone; John from dvxuser.com
I wanted to make a simple matte using Vegas and Photoshop. My goal being to use these images: (Scroll down for images and final result please) http://www.dvxuser.com/V3/showthread.php?t=39008&page=2 You can see my first goal was to simply drop the Photoshop layer 'On top of' the Live Track and I assumed it would cover it up but it didnt work out that way. In fact, the final comp: http://img517.imageshack.us/img517/3...nedude24wc.jpg Has elements of the original live plate that I assumed would be covered up by the Photoshop element. I have tried every combination I can think of using the tracks and composite options and am lost. So I leave dvxuser and seek the advice of the Vegas masters at dvinfo. Thanks |
#1213 |
Sponsor: JET DV
I'm not exactly following everything you're doing. However, coming out of photoshop, why not make the area you wish to show through be transparent? PSD and PNG can both handle transparency fine.
#1214 |
Sponsor: JET DV
Yes. That's what I was talking about. Just drop the veg onto a new timeline and everything's brought over. Probably should have mentioned it's only available in Vegas 6.
#1215 |
Thank you for responding Edward
In simplest terms and for illustration only: http://img518.imageshack.us/img518/662/foredward5ei.jpg That is what I would like to do. I have been using either TIFF or JPEG but will try PNG or PSD right now |
