Vegas Video discussions from 2005 (Q3Q4) - Page 76 at DVinfo.net
Old November 17th, 2005, 01:09 AM   #1126
Film-like color curves with legal levels
What they are:
If you just do a s-shaped gamma curve in Vegas, that can actually push colors below and above digital black levels, causing clipping and loss of image detail in highlights and shadows. That isn't film-like at all. To get things right, you need to get color curves with points at digital black and white level.
Download them off of:
http://www.glennchan.info/Proofs/dvi...lor-curves.veg
You can read the text if you want. But if you're lazy, open up the first and last clips and save those as presets.
2- Note: You should be using the Sony DV codec (this is the default in Vegas5 and V6), and targetting DV or MPEG2 via DVD architect.
If you are targetting other formats, it may be "computer RGB" color space and these curves are kinda inappropriate. Apply the color corrector filter with "convert studio RGB to computer RGB" or the levels filter.
Enjoy!
Glenn Chan is offline
Old November 17th, 2005, 01:24 AM   #1127
Magic Bullet Editor's / Wrong Levels
I don't really use MBE but was wondering how you'd get proper levels using it. A lot of the time you want to work with studio RGB within Vegas (16-235 instead of 0-255). MBE always pushes values towards 0-255, which is not what you want.
The following would work, but is kind of a waste of rendering time and MBE's floating point processing:
Use the color corrector, "studio RGB to computer RGB" preset
MBE
Use the color corrector, "computer RGB to studio RGB" preset
The downside is the extra rendering and banding you might pickup along the way.
Old November 17th, 2005, 09:25 AM   #1128
Glenn,
A little over or under won't hurt anyone. Particularly, super-whites up to 110% IRE (255) tend to work just fine. Plus, you're going to run everything through a Broadcast Safe plug-in prior to broadcast, right?
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline
Old November 17th, 2005, 10:28 AM   #1129
Images: 7
Feathering video edges
Im cant seem to find out how to feather edges on video. for example if im matting someone in another shot but the edges are still a little rough cause of a slight light difference, i just wanna fade the video out onto the other layer. Can anyone help me?
AIM - N film B
www.nbfilms.us
Giuseppe Palumbo is offline
Old November 17th, 2005, 11:28 AM   #1130
Gary,
What's the "Maximum Number of Rendering Threads" I should be using for my machine using Vegas 6? Should I keep it at the default, which is "4" ?
I'm using a Pentium 4 at 3.20 Ghz, hyperthreading, 2GB dual channel DDR SDRAM at 400 Mhz.
--Dale
P.S. I really am learning a lot from your five dvd tutorial. Do you have a learning dvd on Acid 5 or can you suggest one?
Dale Nicholson is offline
Old November 17th, 2005, 11:35 AM   #1131
Sponsor: JET DV
Leave it on the default of 4.
If, for some reason, you want it to behave more like Vegas 5, you can reduce it down to 1.
Edward Troxel is offline
Old November 17th, 2005, 11:38 AM   #1132
Sponsor: JET DV
Add a border FX using the "Soft Edge" preset (adjust as needed). At the bottom of the FX box is a timeline with the word "border" to the left. To the left of that word is a small triangle. You'll need to click on that triangle so that the effect will apply to the resized image instead of the entire screen.
Old November 17th, 2005, 12:38 PM   #1133
Images: 7
thanks a ton, ill try it in a little bit to see how it goes, thanks again.
AIM - N film B
www.nbfilms.us
Old November 17th, 2005, 12:53 PM   #1134
The broadcast safe filter will just clip off values about 235 (if you use the 7.5IRE setup presets). For DVD, you don't really need to use it other than seeing how your video will look like on DVD players that clip illegal colors (illegal as in not in the 16-235 range; many DVD players do this).
The point is... those curves can help you avoid clipping important image detail.
Old November 17th, 2005, 03:26 PM   #1135
Sponsor: VASST
Originally Posted by Laurence Kingston
I'm guessing that this is a Centrino (Pentium M processor) system, in which case the 1.6 processor speed as efficient as a Pentium 4 3.2 GHz system so processor speed wise he's probably going to be fine.
I am not seeing this in my testing. I have a Pentium M 1.8Ghz laptop and a Pentium 4 3.0Ghz desktop and the VASST render test takes almost twice as long on the Pentium M 1.8 when compared with the Pentium 4 3.0. So a PM 1.6 is no where near a P4 3.2! I would definitely avoid Pentium M’s for video work and get a laptop that has a real Pentium 4 or AMD.
Here is what I observed using the original VASST render test on the PC’s I have used Vegas on:
Pentium 4 1.7Ghz = 3:21
Pentium M 1.8Ghz = 2:48 (33 seconds faster than P4 1.7)
Pentium 4 3.0Ghz = 1:35 (73 seconds faster than Pentium M 1.8)
So while the Pentium M 1.8 is faster than a P4 1.7, it is not even close to a P4 3.0
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline
Old November 17th, 2005, 03:56 PM   #1136
Audio problem, deleted track, need best way to recover
For example.
I have a three camera edit, with three associated audio tracks. I deleted one of the audio tracks. What would be the best way in vegas to re-connect the audio.
Any ideas?
I have tried just bringing in the avi and moving the audio to match but it doesn't work very well. I have cut out sections and it doesn't sync up?
Jon
Jon Omiatek is offline
Old November 17th, 2005, 04:27 PM   #1137
Sponsor: JET DV
The easiest option is via scripting. For example, if you delete the audio - select the video and Excalibur can bring back the audio. If you delete the video, select the audio and Excalibur can bring back the video. Ultimate S can also return the missing audio for a video event.
To do it manually, you can double-click the event, open it in the trimmer (which will have that section selected) and then return the audio.
Old November 17th, 2005, 04:37 PM   #1138
Jan Ozer says the winner is - Vegas!!!
This month's issue of eventDV has Jan's final article,
Battle of the Software NLEs, Part 4: Slideshows, Rendering, and Conclusions at
http://www.eventdv.net/Articles/Read...rticleID=10771.
Final scores are as follows:
Premiere Pro - 18
Final Cut Pro - 21.5
Xpress Pro - 14.5
Liquid Edition - 17.5
Vegas - 23.5
There are several comments he made over the course of the series that I'd disagree with him on (such as no batch render capabilities in Vegas 6) but at least he's finally seen the light :-)
Mike
Mike Kujbida is offline
Old November 17th, 2005, 05:21 PM   #1139
good read. what nle preference did he have before?
Neil Camero is offline
Old November 17th, 2005, 09:57 PM   #1140
I assume it's just DV as I tried renaming it to .avi and it plays but no luck as it is still out of sync... it doesn't "go out of sync" it just IS out of sync in vegas... I render a small part in the middle and it's off. I am working on a 2.4ghz celeron with 1gig of ram. It was captured and edited on a 1ghz G4 and there were NO sync problems what so ever on his system. and playing the 2gig file in media player 6.4 also has no problems all the way to the end.
Just checked and it's out of sync in dvda 3 also :-/
Kevin Richard is offline
