Vegas Video discussions from 2005 (Q3Q4) - Page 66 at DVinfo.net
Old October 26th, 2005, 07:39 AM   #976
If you have a track with a very few loud noises, it's usually better to isolate those points, split the events and lower the volume of each of those loud noises manually and then set the level of the overall track to where you want it in relation to the rest of the tracks.
Compressors are very good for adding presence and clarity by putting everything to an average level but they also raise the volume of the lower levels so they can bring up noise and cause a pumping effect if there are big differences between the loud and quiet sounds.
Limiters only affect the high volume sounds and if they are too high in relation to the rest of the track then it will sound squashed and unnatural at those points.
Glenn's suggested settings are very good but will work better if you've manually tamed any large peaks beforehand. This is a trick used in the audio world to enable one to use compressors and limiters and still have them sound natural.
Tony
Tony Rockliff is offline
Old October 26th, 2005, 08:38 AM   #977
Old Boot
"I also highly recommend monitoring your Vegas timeline via firewire on an external calibrated monitor so you can see the black levels more accurately."
.. oh yes . . oh yes . . .
Graham Bernard is offline
Old October 26th, 2005, 10:08 AM   #978
Tony: The "Studio RGB to Computer RGB" is for converting from 16-235 space (blacks at 16, whites at 235) to 0-255 (blacks previously at 16 now end up at 0, whites previously at 235 end up at 255). It's not the appropriate filter for handling the 0 / 7.5IRE setup issue.
Here's my explanation of the whole issue, and I hope it doesn't confuse you.
Analog levels:
Standard analog black level for non-Japan NTSC is 7.5IRE. For Japan it's 0 IRE.
Standard white level is at 100IRE for both Japan and non-Japan NTSC.
Digital levels:
DV records in Y'CbCr format. Y' is the luma component and the legal range for those values is 16-235.
If you are using the Sony DV codec, 16 on the histogram corresponds to a Y' value of 16. And 235 to 235.
The Microsoft DV codec doesn't do this (which is why the Sony DV codec exists, I believe). The Microsoft codec does 0-255.
When converting from digital to analog, a Y' value of 16 should be converted to 7.5 IRE for non-Japan NTSC. Not all North American equipment does this (most consumer equipment doesn't do this). Most equipment will put a Y' value of 16 at 0 IRE instead, which may not really look all that bad (increased contrast, loss of shadow detail, darker image [but most TVs make dark images look good]). It's bad if you are adjusting your video levels and trying to make things look better.
There is a lot of confusing information on this subject out there, hopefully I'm not adding to the confusion.
2- I believe Japanese camcorders record black at proper digital black level (Y' = 16). I can check this when I go home.
3- Dale:
Chances are, the range of light values in a scene exceed the contrast/exposure range your camera can capture. There's usually some specular reflection that is a lot brighter than everything else. Also, skies on a sunny day are problematic.
I would not use a light meter. In video you can see your results instantly if you drag along a field monitor (a CRT-based one).
Do not use a consumer monitor in this situation. Almost all of them are made to make pictures overly bright, which will make underexposed footage look good. And you're not going to catch that. You could probably calibrate the consumer monitor not to do that, but then they also do things to your picture which you may not know about (i.e. flesh tone correction, noise reduction, edge sharpening/enhancement, hue is probably slightly off).
This gets into tricky issues, because a broadcast-grade monitor is supposed to be the standard and consumer equipment should fall around that standard. But consumer equipment, on average, is overly bright. It doesn't fall around the standards.
A big advantage of a broadcast monitor is that they are easy to calibrate, and you know it won't have picture cheats like flesh tone correction. It's probably better to make things look good on a broadcast monitor than a consumer monitor.
Glenn Chan is offline
Old October 26th, 2005, 10:49 AM   #979
Hi Glenn,
Thanks for the expanded explanation. I've often wondered why the preset was called "Studio RGB to Computer RGB" and have wondered if it was technically (or logically) the right tool.
All I can say is that after extensive testing it is the tool that corrects the black level problems introduced by my particular system/hardware and software line.
If I render using the Vegas Mainconcept or Procoder encoders after using that preset my DVDs come out with perfect black levels. If I don't they're washed-out. If I render using the TMPGEnc encoder I have to also select its CCIR601 expansion preset.
I'm using a calibrated Panasonic broadcast monitor.
Tony
Old October 26th, 2005, 01:01 PM   #980
Yeah, I got my terminology a little confused there. I don't want to CLIP my shadows, I want to COMPRESS them.
O.K. So color curves it is.
I'll be looking forward to the .veg.
Thanks Glenn!
DJ Kinney is offline
Old October 26th, 2005, 06:20 PM   #981
Jubal 28
Originally Posted by Gary Bettan
We agree completely! That's why we've put together special bundles with VASST & Sony that include VASST training and trial versions of Ultimate S & Gearshift with any Vegas purchase.
We're also offering a bundle of VASST training & Ultimate S.
We've posted an interview on our site with Douglas Spotted Eagle that talks about Vegas, Ultimate S & HDV. Check it out http://www.videoguys.com/vegas_spot.html
Gary
Very nice! I never mind seeing my own work plugged, either . . . :)
Looks like a great deal.
David Jimerson is offline
Old October 26th, 2005, 06:36 PM   #982
Jubal 28
There is a quicker but less-precise method; instead of using a bezier mask on the upper event, you'd use a pre-made cookie cutter. The effect is more or less the same; you're isolating your foreground element and eliminating the background from your upper track, then applying the color-correction to the lower track. Get it in fairly tight, and you may have what you want -- and if you adjust opacity or add edge blur to the upper layer, you can hedge the color-correction in a little bit. It might make for some cool effects, too.
Old October 26th, 2005, 08:24 PM   #983
This is a perfect example of a time when what I mention in this thread
http://www.dvinfo.net/conf/showthread.php?t=53385
would come in useful.
Old October 27th, 2005, 12:26 AM   #984
Hey Dave:
I purchased my Ultimate S 2.0 with Celluloid this morning!
Ray Sigmond is offline
Old October 27th, 2005, 09:43 PM   #985
Boris FX8 & Vegas
Has anyone loaded up the Boris FX8 plus-ins yet? I am interested in how well the image stabilzation tool works, since it is not native in Vegas and I can always improve my hand-held stuff.
You are either growing or dying.
Bob Costa is offline
Old October 28th, 2005, 11:11 AM   #986
Dropped Frames
Hello everyone..need a little help.
I transferred about 6 minutes of video last night to V6. After the capture, a screen indicated that approximately 400 frames were dropped. I'm shooting a Pana AGDVC200 at a shutter speed of 1/100th. Transferred via firewire to a Pentium 4, 2.66 Ghz, 1 gig of ram. Any suggestions or thoughts?
Thanks - David Bird
David Bird is offline
Old October 28th, 2005, 11:42 AM   #987
How large did you have the preview window?
Hard drive defragged?
Separate Hard drive?
Anti-virus turned on?
The Vegas FAQ: http://www.vasst.com/sony/default.aspx has lots of dropped frame suggestions.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
Douglas Spotted Eagle is offline
Old October 28th, 2005, 04:52 PM   #988
Preview window is less than 1/4 of the screen, hard drive has not been defragged...just installed it about 1 month ago. I have a separate 250 gig, 7500 rpm drive specifically installed for video footage...However, now that I think of it, the footage that was captured went to "My Documents" for some reason, which resides on my C: drive....
David Bird
Old October 28th, 2005, 06:30 PM   #989
Chroma Key - Can't see underlying track
I have an avi on the upper track...it's been chroma keyed...and another track below. Can't see the lower track...I know I'm missing a setting.... ?
David Bird
Old October 31st, 2005, 02:27 PM   #990
Vegas 5 Audio & Software Synths
Hey All,
Hope everyone is having a Happy Halloween.
I've been using Vegas 5 to record audio for the last year or so and it works great. But I can't seem to find a way to record software synths directly into Vegas.
For guitars, vox, foley work, I'm running into an Echo Mona which gets along with Vegas just fine.
For soft syth things, I've got an M-audio midi keystation plugged via USB into the computer running M-audio Keyrig and a few other virtual synth programs.
How do I set Vegas to capture those sounds?
Any help, as always, is greatly appreciated.
Dan Barnhill
Dan Barnhill is offline
