Vegas Video discussions from 2005 (Q3Q4) - Page 48 at DVinfo.net
Old September 22nd, 2005, 11:40 AM   #706
Just make sure that your preview window is set to "Best/Full" or you won't get the best quality grab.
Another option is to use a script like the Automated Photo Snapshot one for doing this. It's a part of the collection at http://s92274348.onlinehome.us/vegas.html
Mike
Mike Kujbida is offline
Old September 22nd, 2005, 11:46 AM   #707
Sponsor: JET DV
Do a search here for "DivX" and/or "XVid" which should point you to the proper codec to install so that Vegas can "see" the video.
Edward Troxel is offline
Old September 22nd, 2005, 11:52 AM   #708
Sponsor: JET DV
Depends on what you mean by "Real Time". You can apply these effects, press "Play", and the timeline will playback in real time WITH those effects applied. However, if it cannot keep up, a couple of things happen:
1) Preview Quality: You can change the level of preview quality. The default "Preview" is a reduced quality version. For a higher quality, bump it up to "Good"
2) Reduced Framerate: If the computer cannot keep up with the effects in real time, it will start dropping frames. This is all system and effect dependent. Naturally, preview set Preview quality will drop fewer frames than one set to Good quality.
One really neat thing you can do is create a selection area and start a looping playback. Now, while the playback is looping, open the Effect window and start adjusting. You'll see the adjustments LIVE as you make them.
There is no hardware device that will help with the above. If you MUST see higher resolution than the above provides, a couple of options are RAM-Rendering and Prerendering.
Old September 22nd, 2005, 01:18 PM   #709
A- Upgrading your CPU would help, although it is pricey.
Seeing Spot's VAAST demonstration, the dual core dual opteron machine he has (4 cores, about equivalent to 3.2ghz Pentiums each) is fast. *Real performance is less than 4X faster... probably about >2X faster.
If on a budget, you may be able to grab a Dell Inspiron 9100 for cheap and cannibalize your old machine (upgrade to dual core... may be like 40% faster than what you havenow). The base system can be a good deal, check hot deals sites for the US. Upgrades are way overpriced.
B- More RAM means longer RAM previews and more stuff can get buffered into memory while you loop.
C- Try Celluloid or Reelpaks (from VAAST) [i forget the exact name], as they render much faster than Magic Bullet. Some of the looks involve the gradient map, which can create banding in some cases. The workaround is to use the secondary color corrector to add tints instead.
Glenn Chan is offline
Old September 22nd, 2005, 01:47 PM   #710
DVD intro sequence?
First, I have been lurking for a few days now and let me say this forum
is awesome. I am a super novice user of Vegas but have been playing around with it for < a year now..Used it last winter to edit a motorcycle Stunt DVD and since then I have been trying to get better..
So my question is related to DVD architect. How do I make a DVD so that it plays an intro movie sequence before the main DVD menu comes up ?
We are currently doing another stunt dvd this winter and I would like our animated logo and trailer to play before the menu pops up ??
Cheers and thanks again for all the great tips and advice I have read thru..
Cheers
SC
Steve Clee is offline
Old September 22nd, 2005, 01:54 PM   #711
Sponsor: JET DV
Set the Intro Video as the "First Play" option and then have it "End Action" to the menu.
Old September 22nd, 2005, 02:17 PM   #712
Got it...thanks....
Cheers
SC
Old September 23rd, 2005, 07:54 PM   #713
Recording audio
How can I record just audio with Vegas? I also have a Canopus ADVC 110 connected to this system. I switched a dip-switch on the bottom of the ADVC but it didn't help.
Frank Delucia is offline
Old September 23rd, 2005, 08:43 PM   #714
Sponsor: JET DV
Via firewire? Use Scenalyzer Live
Via your soundcard? Straight to the timeline!
Old September 23rd, 2005, 10:58 PM   #715
Merging multiple clips onto track
I shot a series of clips which are no more than 2 seconds long but need to be played in reverse and sped up. There are about 20 of these clips and I was wondering if it's possible to add them all as one onto Track 1 instead of individually so that the envelope edit for time affects every clip on the track, somewhat akin to the "Flatten" feature in Photoshop.
Thanks guys
Stephen Griebel is offline
Old September 24th, 2005, 12:11 AM   #716
Add the 20 clips to the timeline and select all of them. Right-click on and choose reverse. While all still selected hit G to group them, then Ctrl/drag the right edge of the last one to the left.
Gary
Gary Kleiner is offline
Old September 24th, 2005, 08:19 AM   #717
Much abliged
Old September 24th, 2005, 09:00 AM   #718
HDV m2t workflow if going back to m2t? possible?
Hello. I am working on a project for a client and they want me to edit some footage they shot in HDV. I have the m2t files, and I have used HDV before as I have an FX1, but I have only converted them to quicktime or AVI's to edit them and not worry about getting them back to mpg/m2t files. But they want me to do this. Is it even possible without Cineform? They also want me to create a log of some sort, how do I do this?
sorry for the noob-esque questions.
thanks
Jamie
Jamie Francis
Double or Nothing Productions
http://www.francisbros.com
Jamie Francis is offline
Old September 24th, 2005, 01:01 PM   #719
Hey there. I know this thread was quite a while ago, but no one suggested a motion blur envelope, which would have accomplished the blurring of light without blurring anything else, and it's built into Vegas. At least, Vegas 6.
DJ Kinney is offline
Old September 24th, 2005, 07:48 PM   #720
thanks
Jamie
Usually helps those who would love to offer assistance if you give some idea of what computer platform you're using (Mac/PC) and what editing software (NLE) you currently have.
This answer will be "hit or miss" without such information, but:for PC - if you get the demo version of AspectHD or ConnectHD and your NLE can write to MPEG2 Transport Stream of the same frame rate and bitrate of the HDV stream used, you can then use the Cineform HDLink utility to write back to camera. (tip: m2t is MPEG2 transport stream, so any *.mpg that is MPEG2 TS just needs the three character file type extension changed to .m2t and HDLink can use it... this works in reverse for player apps and NLE's that don't "natively" support HDV)
For Mac, I believe LumiereHD provides much the same functionality...
Steve Crisdale is offline
