Vegas Video discussions from 2005 (Q3Q4) - Page 40 at DVinfo.net
Old September 8th, 2005, 07:46 AM   #586
RED Code Chef
I have no idea what the problem is you are having. Add your credits to your
video 2 track. If you want them cropped to letterbox like the rest of the
footage you should be done at this point. If not. Just make sure the letterbox
mask either stops at the points the credits begin, or if that leaves you with
no credits start a new mask there that has white (I assume you are using
white where video must show) in the FULL picture (not just in the middle).
Another option would be to render your movie to DV AVI. Start a new project
and load your just rendered movie. Now put some credits after it and render
that to your final format.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old September 8th, 2005, 10:25 AM   #587
Thanks James, I think this is the route I'll go then.
Shane Schmidt is offline
Old September 8th, 2005, 10:40 AM   #588
I'm at a loss at how to get started using Bezier masking.
Any tips? Anything in your newsletters on this?
Dave Largent is offline
Old September 8th, 2005, 10:45 AM   #589
Sponsor: JET DV
Vol 3 #3 (the last issue to date).
Edward Troxel is offline
Old September 8th, 2005, 11:42 AM   #590
Credit Roll Question
I can't figure something out in the Credit Roll. On my opening credits I have the "Credit Roll--Scrolling on Transparent--Timed Sequence" selected. When the credits enter from top to bottom or vice-versa they go from one edge of the screen to the other (on both my timeline preview window AND my render), which is great. But when the credits enter from left to right or vice-versa, only on the timeline preview do they enter from and go to the edge of the screen, NOT on my rendered version. They appear and disappear quite a bit from the edge of the screen. What should I do? Thank you.
Ruben Pla is offline
Old September 8th, 2005, 12:06 PM   #591
Thanks Mike, but I will need to find out how to use the bezier tool as my cut-out needs to be more precise than can be accomplished with the cookie cutter. I was hoping there might be a simple step-by-step description somewhere such as in Edward's newsletters.
Tony
Tony Rockliff is offline
Old September 8th, 2005, 12:12 PM   #592
Sponsor: JET DV
Vol 3, #3 - look in the Beginner's Corner section.
Old September 8th, 2005, 12:19 PM   #593
Thanks, Edward!
Old September 8th, 2005, 05:30 PM   #594
FX1 not being recognize
I got my vegas 6 co-exhisiting with vegas 4. for some reason i cannot have vegas 6 recognize the fx1 as being my hd deck..it keeps thinking its a dv deck. How am I suppose to upload my hd footages? My comp won't let me the comp is thinking its just a dv cam. I been capturing with my fx1 onto vegas 4 but now i have 6. I am using windows XP.
Fred Foronda is offline
Old September 8th, 2005, 05:32 PM   #595
Are you sure that the FX1 has the firewire port set to HDV and not DV downconvert? Check the in/out menu while in VCR mode.
Boyd Ostroff is offline
Old September 8th, 2005, 05:35 PM   #596
i.link convertion must be off on the fx1 ?? let me try that.
thanks!!
Old September 8th, 2005, 05:49 PM   #597
DVDA2 not showing objects.
Ok, I'm stumped. After a couple of dozen authoring projects I have ran into my 1st snag with DVDA2.
I have a menu with a looping animated background video that has a "Play Movie" and a "Scenes" object. After preparing & burning the dvd, both buttons are missing but the underlines are is still there and the objects still function (though you cannot see them).
Now I checked the object placement & it's on top as it should be. I have also tried replacing the text with an alpha image and the same result happens.
It appears that the background video is covering it even though I have both objects sent to the "top" position.
So far I have burned 5 coasters trying to figure out just why this is happening.
Thanks in advance.
Shane
Old September 8th, 2005, 05:55 PM   #598
I'm assuming you want to edit HDV and not DV. In that case, the blue HDV LED next to the i.Link port should be glowing. If the DV LED is glowing instead then you need to go to the IN/OUT REC menu, scroll down to i.LINK CONV and turn it OFF.
Old September 8th, 2005, 05:56 PM   #599
thanks!!
still not recognizing my fx1
Old September 8th, 2005, 06:01 PM   #600
Sorry, then it may be a PC or a Vegas issue and I can't help you there....
