Vegas Video discussions from 2005 (Q3Q4) - Page 34 at DVinfo.net
Old August 27th, 2005, 04:20 PM   #496
Thanks Brian, that's what I was looking for. Vegas does have "Multi-Band Dynamics" and I found the de-esser as an option. Works great.
Thanks to Mike and DJ too, I learned more. Since I got these BX8s and can hear better, I have all kinds of things to learn about audio.
You are either growing or dying.
Bob Costa is offline
Old August 27th, 2005, 08:46 PM   #497
Same problem.
I've got this issue working with Sony Support. AMD 64 4800 dual core, etc, with the NEC 3250. There are no driver updates I could find. Neither V6, DVDA3, nor DVDA2 see the drive.
Meantime, I rip my CDs with WMP and burn my DVDs with Nero Recode (after authoring and "preparing" in DVDA3).
You'll find the odd post here and there about this drive and Vegas, no solutions I've found other than the workarounds.
Darryl
Darryl Grob is offline
Old August 28th, 2005, 06:31 PM   #498
Images: 7
Big difference from 4 to 6?
Is it worth me getting 6? ive learned 4 pretty good and is it alot different and worth upgrading?
AIM - N film B
www.nbfilms.us
Giuseppe Palumbo is offline
Old August 28th, 2005, 07:14 PM   #499
Sponsor: JET DV
Read my April 2004 newsletter to see the difference between Vegas 4 and Vegas 5. Then read the April 2005 newsletter to see the difference between Vegas 5 and Vegas 6. That should give you the major differences from 4 to 6.
Edward Troxel is offline
Old August 28th, 2005, 08:45 PM   #500
As Edward said, read his newsletters. But if you're lazy and just want someone to tell you what to do - then yes, upgrade :). Not for 6, cause I think 6 is really a ripoff, but for 5.
Aaron
My Website
Meat Free Media
Aaron Koolen is offline
Old August 29th, 2005, 02:41 AM   #501
Ah, but 6 has that totally new way of handling 24p pulldown conversion which looks really good, AND is capable of editing HD. So not so much of a ripoff if those things are in your future.......
DJ Kinney is offline
Old August 29th, 2005, 03:28 PM   #502
Yes, the feature that makes Vegas 6 a worthwhile upgrade for me at least is the frame rate conversion. Vegas 5 and earlier treat interlaced footage like every other non-linear editor: like 30 interlaced frames. Vegas 6 treats interlaced footage almost like 60 progressive frames. This makes a huge difference on frame rate conversions. 24p looks as clear as the 60i starting footage (which of course is still not as clear as native 24p). NTSC/PAL conversions look MUCH better now as well. PAL to NTSC is so good, I wish I had a had a PAL camera. I'd shoot PAL all the time and convert it to NTSC, and use the extra lines of resolution for rendering widescreen versions and deshaking.
Laurence Kingston is offline
Old August 29th, 2005, 03:52 PM   #503
Well that is a real bummer. Please keep me up to date with what Sony has to say about this issue. (I have been logged on with administrator rights when seeing this issue)
Unfortunately I do not have Nero or any other burning software, so I can not burn a DVD. I know of some free CD ripping tools, are there any free DVD burning tools anyone could recommend?
Matt McConnell is offline
Old August 29th, 2005, 07:27 PM   #504
Nero 6.6 for US $79.99
http://ww2.nero.com/enu/index.html
Hard to beat, not free, but quite an ensamble. I only download and use the first 2 packages of the 4 bundles. Nero Recode will take your authored DVD Video_TS and drag the Audio_TS with it, then burn quite nicely. Let me see, if memory serves, click, click, click, click, burn. Darryl
Old August 29th, 2005, 08:10 PM   #505
Compressing mpeg2
I need to compress an mpeg 2 file to fit onto 1 dvd. Can Vegas do this or do I need a separate software?
Kevin Munn is offline
Old August 29th, 2005, 09:00 PM   #506
Tricky PIP (for me)
Hello hello,
I've shot some basketball footage (2 cameras) and am trying to get a particurlar PIP effect. Both shots started full back (wide? haven't got the jargon down yet), while a player was at the free throw line. One camera zoomed in to catch half the amount of information. His reaction while the ball was in flight was very interesting (no, no, no...yes!), so I'd like to put that in the top right hand corner.
My problem is that the zoomed shot doesn't keep him in the centre of frame (and he moves some) - so I can keyframe to follow him, but this just gives me a track with a small picture that moves over various areas of the second track. Is there any way I can keep this in the top right of the second track?
I've been playing with this for awhile, but no luck - can anyone offer a suggestion?
Steve
Steve Madsen is offline
Old August 29th, 2005, 09:17 PM   #507
Sponsor: JET DV
Use Pan/Crop to zoom and pan and follow the player.
Use Track Motion to actually create the PIP.
Old August 29th, 2005, 09:20 PM   #508
Sponsor: JET DV
Vegas can do it but you'll be much better off starting with the original (i.e. non-mpeg2) footage. However, it is quite possible for Vegas and/or DVD Architect to recompress an MPEG2 into a smaller MPEG2 file.
Old August 29th, 2005, 09:30 PM   #509
How would I go about doing that? I tried setting the quality to about half but it keeps rendering to the same file size.
Old August 30th, 2005, 02:54 AM   #510
Thanks Edward. It appears I'll have reposition many times in track motion, but it works perfectly.
