Vegas Video discussions from 2005 (Q3Q4) - Page 27 at DVinfo.net
Old August 21st, 2005, 12:14 PM   #391
Sponsor: JET DV
Yes, just download it and try it in demo mode. Use the option to capture the secondary audio channel to a separate wave file. See if the other half is there.
Edward Troxel is offline
Old August 21st, 2005, 01:02 PM   #392
Timely, concise and accurate
It's why I am beginning to LOVE you.
ED! Thanks a bunch.
sincerely,
ian
Ian Slessor is offline
Old August 21st, 2005, 01:41 PM   #393
Thanks Edward, i will give that a try..
Mike Moncrief
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline
Old August 21st, 2005, 03:15 PM   #394
Dear Edward,
Thank you for the correct answer, as always.
I used the feather option and it works great.
Thanks again.
Dan Keaton
Augusta Georgia
Dan Keaton is offline
Old August 21st, 2005, 03:26 PM   #395
Edward, can you throw in the artistic talent to make that 16x16 pixel image look like something other than a blob? Knowledge is only half the battle here, what page do I find 'artistic talent' on?
Fear No Weevil!
Patrick King is offline
Old August 21st, 2005, 03:26 PM   #396
Viewing "fuzzies" in and out!
I have a scene in Vegas that keeps going in and out from sharp to fuzzy. The original footage was fine, as was the timeline edit. But now, for some reason, when I view both the timeline edit and original footage, it's sharp for a few seconds, then fuzzy, then sharp, back and forth. I must have changed some setting somewhere in Vegas, but I can't find where. Can someone please help me? Thank you.
Ruben Pla is offline
Old August 21st, 2005, 03:31 PM   #397
Thanks Guy's
That's perfect. I know exactly what to do..Thanks again for your help. Not sure what I would do without this forum.
Cheers :)
Darrin McMillan is offline
Old August 21st, 2005, 06:08 PM   #398
iMovie and Vegas
Hey all...can I import clips that were captured in iMovie into vegas? I mean, it isn't working as I'm trying it, but I'm thinking there's a codec.
DJ
DJ Kinney is offline
Old August 21st, 2005, 07:44 PM   #399
iMovie uses the DV stream format, which doesn't even work well in Final Cut Pro (no timecode or user bits, and audio is formatted differently).
You should be able to read DV stream with QUicktime Pro on PC, and you could use that to convert. Vegas may also be able to read the DV stream format.
2- Have you tried adding a .mov extension to those files?
Glenn Chan is offline
Old August 21st, 2005, 07:54 PM   #400
Sponsor: JET DV
16x16 is REAL tough to be creative in. I know from EXPERIENCE creating all the little icons for Excalibur.
Old August 21st, 2005, 08:00 PM   #401
Sponsor: JET DV
What is your preview settings on? What is the framerate as it plays back? Any effects on the clip/track/project/media?
Old August 21st, 2005, 08:17 PM   #402
The playback frame rate is 29.970(NTSC) and the setting in the preview window is "Preview (Auto)." There are no FX plug ins in the track or events.
Old August 21st, 2005, 08:25 PM   #403
No. Changing the extension doesn't work. I'm just going to go back and render to quicktime and bring them back into Vegas that way.
Thanks, though. What a pain!
Old August 22nd, 2005, 06:39 AM   #404
check it on an NTSC monitor or TV hooked up thru your FW connection on the camera. Do not trust the computer screen. I have had this happen on a couple of pieces and it drove me crazy until I checked it on my NTSC monitor and it was fine. For some reason on occassion the computer monitor sees it as soft. No rhyme or reason to it but don't panic. Make sure of what you have before you panic. :-)
Don
Don Bloom is offline
Old August 22nd, 2005, 07:14 AM   #405
Originally Posted by Edward Troxel
Sounds like you need to "end action" from one to the other. However, there WILL be a slight pause between clips when done this way. I always render to a single file for the entire video. Then it will easily play straight through with no pauses.
If it is a "single" file then the DVD plays automatically? What if, I want it to pause and allow the viewer to press return/play key to start the video? How do i do this?
Thanks.
Danny Santos is offline
