Vegas Video discussions from 2005 (Q3Q4) - Page 104 at DVinfo.net
Old December 29th, 2005, 03:12 PM   #1546
Thanks Ed,
Again...................
"We don't have any money, so we will have to think" Ernest Rutherford
Colin Rayner is offline
Old December 30th, 2005, 06:35 AM   #1547
Mouse scroll timeline
I wonder if it's possible work with scroll weel on mouse , for frame by frame editing the timeline. With simple drag the edit line, it's not so easy to find desired frame to cut.
Regards.
Zdravko Jancevski is offline
Old December 30th, 2005, 06:59 AM   #1548
By enlarging the timeline you will be able to get to frame by frame-you can use the mouse wheel to enlarge the timeline or use the + sign on the right side of the timeline to do the same
Don
Don Bloom is offline
Old December 30th, 2005, 01:33 PM   #1549
AC-3 to DVD Architect
Just checking, having rendered my project into 2 files, Mpeg2 for the video stream and AC-3 for the audio stream, I import the two into Architect, do nothing more to the audio file, create a button for the Mpeg2 file and all is well?
Every resource that I have checked is quite vague on what to do with your AC-3 file once you add it to your project in DVD Arch.
Old December 30th, 2005, 01:39 PM   #1550
There is nothing more to do, or that can be done with the AC3 file. If it's the same name as the MPEG, and in the same folder, DVDA should automatically marry the two together. If for some reason it doesn't, double click the mpeg to load it into the Timeline, and drag the AC3 file to the audio track in the timeline.
That's all you need to do.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old December 30th, 2005, 01:45 PM   #1551
Video Timer
Is there a way I can insert a video timer, that will count with the video. What I want to do is give a sample video that someone can look at and say for example: At 3:43 minutes there is XYZ and I want that cut out.
I'm looking for a timer over the video itself.
Steven Davis is offline
Old December 30th, 2005, 01:45 PM   #1552
Thanks for that Spot, I have the Intro to DVD Arch and V6 Fasst but didn't get my head around that.
Thanks again
Old December 30th, 2005, 03:23 PM   #1553
Sponsor: JET DV
Look at the Timecode FX. Just add it to the track and that should do it.
Edward Troxel is offline
Old December 30th, 2005, 05:29 PM   #1554
Thanks Edward, since I'm doing it on a multi track project, I just added it to a transparent layer. Thanks again. BTW, I've been enjoying your newsletters.
Old December 30th, 2005, 08:23 PM   #1555
Sponsor: JET DV
Thanks. Glad you got the timecode to work and you're finding the newsletters useful.
Old December 31st, 2005, 12:11 AM   #1556
<since I'm doing it on a multi track project, I just added it to a transparent layer.>
You could drop the Timecode FX right onto the Preview Widow to apply it to the whole project.
Gary
Gary Kleiner is offline
