Stabilizer Plugin for Vegas? - Page 5 at DVinfo.net
Old March 27th, 2009, 07:55 PM   #61
Here's the answer I got from the guy at SteadyHand:
Rick,
It does run on Vista 64.
It handles some HDV -- there are many formats.
No it doesn't open m2t files. Only AVI in AVI out.
Rick Diaz is offline   Reply With Quote
Old April 1st, 2009, 04:26 PM   #62
Erik.... I too get that message in Vegas 8.1, so dropped back to 8.0c, where I experience the problems described above.
Old April 8th, 2009, 03:10 PM   #63
i dont have time to play w/this yet. is it true that it won't handle m2t? i need this on HD 1440x1080i .m2t footages =(.
can som1 confirm?
bow wow wow
Yi Fong Yu is offline   Reply With Quote
Old April 8th, 2009, 03:16 PM   #64
Rick,
I think that's it.
Sam Houchins II is offline   Reply With Quote
Old April 8th, 2009, 03:38 PM   #65
can som1 confirm?
If you mean Deshaker, yes it will work with m2t files so long as you are using the script from within Vegas Pro.
Old April 10th, 2009, 11:57 AM   #66
so u can use deshaker on .m2t only if u have 32-bit OS, otherwise people w/Vista64 (like me) won't be able to use it unless it's .avi yeah?
bow wow wow
Old April 10th, 2009, 12:47 PM   #67
Sponsor: JET DV
Actually, the script in Vegas is rendering out to AVI even in the 32-bit version so the same procedure should work in 64-bit.
Old April 10th, 2009, 02:52 PM   #68
I use Vista 64. The OS is not an issue with Deshaker, but VDub does not natively recognize m2t files in standalone mode. You have to use the Deshaker script.
