Anybody get "Preview on External Monitor" to work? - Page 2 at DVinfo.net
Old January 5th, 2005, 12:32 PM   #16
Good points -- I'll try that out.
Jim Lafferty is offline   Reply With Quote
Old January 6th, 2005, 01:19 PM   #17
FYI I use an older Sony converter I have a Sony DSR 11 but I like to keep it off HEAT is a big issue and I think the image is a little better with the converter
Vince
Vince Debart is offline   Reply With Quote
Old November 28th, 2007, 05:18 AM   #18
Originally Posted by John Gaspain View Post
does it play in full resolutuon at full FPS?
... Will the output look just like it does in the vegas preview screen...just on an interlaced TV....
Pls, what do u mean by FPS and an interlaced TV?
John P
John Portharcourt is offline   Reply With Quote
Old November 28th, 2007, 05:24 AM   #19
Is external preview is done via firewire majorly?
Originally Posted by Edward Troxel View Post
External preview is done via firewire....
Hi (to Edward Troxel) won’t there still be an interface btw PC and TV? Or do u connect i-link/IEEE 1394 to TV directly? Pls educate me.
Thanks John P
Old November 28th, 2007, 05:31 AM   #20
What is this RMA all about?
Originally Posted by Jim Lafferty View Post
Also, I'm on a single, 1.6ghz processor setup while my MP board is out on RMA. I have a gig of RAM, too....- jim
Pls, what is RMA, and what is it all about?
Rgds - John Port harcourt
Old November 28th, 2007, 08:25 AM   #21
Sponsor: JET DV
Thanks John P
Computer -> firewire -> Camera/deck/convertor -> S-video/RCA -> TV
Old November 28th, 2007, 09:23 AM   #22
Ed, what if you want to connect and monitor on a high definition monitor? Is it simply a matter of replacing the second-last "S-video/RCA" step with "HDMI/component"? Or is it more complicated than that? (This assumes one has the HDMI/component option, e.g. on an HV20).
Ian Hay is offline   Reply With Quote
Old November 28th, 2007, 10:19 AM   #23
Sponsor: JET DV
For HD, there's a couple options available. One is to use the Secondary Monitor as the display device. Then you would connect to the secondary output of your video card. Another is to use a dedicated hardware card to output HD.
Using Firewire, your preview will be in SD.
Old November 28th, 2007, 08:14 PM   #24
How about a Y adapter from one of the graphics card outlets for 2 computer monitors and use the other graphics card outlet for a HD TV monitor?
Jaums Sutton is offline   Reply
