Timeline selection at DVinfo.net
Old September 5th, 2009, 12:01 PM   #1
Timeline selection
Sometimes the timeline selection accidently appears on the timeline and I want to get rid of it quickly. Is there a simple way to do this. Thanks
William LiPera is offline   Reply With Quote
Old September 5th, 2009, 12:06 PM   #2
to delete a selection on the TL simply highlite it and press delete.
Don
Old September 6th, 2009, 12:04 AM   #3
Old Boot
Don? I could be wrong here, but I think that William maybe referring to not wanting to have a Loop Selection automatically appear, when working? In which case go into Preferences and use the "Collapse loop region . .. ". I use this often when I find that this gets in the way. Try it:
Tools | Preferences | Editing | and uncheck "Collapse loop region when no time selection is present"
Grazie
Old September 6th, 2009, 06:21 AM   #4
Sponsor: JET DV
I always leave the "Collapse Loop Region" turned on. Otherwise, you"ll ALWAYS have a selection area unless you manually resize it to nothing. This option will allow a single click on the timeline to get rid of the loop region. It does have some side effects if you use "i" and "o" in the trimmer, though - so if you see something you used to do acting odd, this may be the reason.
Old September 6th, 2009, 07:12 AM   #5
yeah, I misread the post. I should know better than to answer anything techy at 11:30pm after working a gig. These old eyes get goofy at nite ;-)
Don
Old September 6th, 2009, 08:35 AM   #6
Add first thing in the morning to that list :-)
Old September 6th, 2009, 09:55 AM   #7
Thanks Guys.
