Trying out Vegas 5.0 demo - Where are the track FX? - Page 2 at DVinfo.net
Old January 19th, 2005, 03:23 PM   #16
Sponsor: JET DV
Try disconnecting the Mackie Controller.
Old January 19th, 2005, 07:04 PM   #17
<<<-- Originally posted by Edward Troxel : Try disconnecting the Mackie Controller. -->>>
It worked Edward !!
I removed the Mackie Control in the MIDI section and the FX Buttons work fine.
Are you aware of any issues with the Mackie Control and Vegas? I am using operating system 2.1.2 of the Mackie Control which is the latest.
Ray
Ray Sigmond is offline   Reply With Quote
Old January 19th, 2005, 08:52 PM   #18
Sponsor: JET DV
I am not aware of any specific issues with the Mackie controller. In fact, it is one that is specifically supported. The reason I suggested that was your error message was referencing the the mackie controller as causing the error. Perhaps DSE would have more advice as he has actually used a mackie controller.
Old January 19th, 2005, 08:56 PM   #19
Edward:
Do you think I should try experimenting with the Mackie Control assigned on different MIDI channels? I ahd it assigned to MIDI Channel 3 when the error happened.
Ray
Old January 19th, 2005, 09:06 PM   #20
Sponsor: JET DV
I'm really unsure as I've never used one. Sure wouldn't hurt to try, though.
Old January 24th, 2005, 11:30 AM   #21
Well I ended up re-formatting my computer (it needed it anyways) and everything works fine now.
Thanks guys for all your help & suggestions.
Toogood Studios
Jeff Toogood is offline   Reply
