#1351 |
Hi Rob,
Thanks for the tip. Is there anyway to automate a process which STRETCHES each image sequence by duplicating each frame x number of times? Or is manual dragging each frame individually on the timeline the only way to do it? :oS Dennis EDIT: I figured it out. Basically I'll have to re-import all the images as SEPARATE IMAGES, then change the 'New still image length' in Preferences (Editing) to 5 frames (at 25fps) and drag all the individual images onto the timeline in one go. This should do the trick. |
#1352 |
Sponsor: JET DV
What's an "Adobe Default Windows Sound Driver"? Does it start after doing a reboot? Can you do something to get rid of the Adobe setting?
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#1353 |
Creating DVD
I just rendered and created 2 mpg2 files in Vegas 5. For DVD authoring, I used Sonic MYDVD to create the DVD. Unfortunately, my DVD player will not play it although in the past I have created DVDs and used the same player. The many DVDs I created using Pinnacle Studio 9 and Sonic MyDVD has been successful on this player and other player in the house.
So, what am I doing wrong? 1. Does Vegas 5 support +R. +RW discs? 2. Would it be my MPG2 rendering setup? I am using the standard/default setup such as: Save File as: MainConcept MPEg2 Template: DVD NTSC Video Rendering Quality: Good Frame Rate: 29.97 Aspect Ratio: 4:3 Display Anyone please. Thanks. |
#1354 |
Thanks for the help but turns out that I was just not paying attention closely enough. The Splash Screen for Vegas 6 comes up above any other window, and it came up above that adobe sound driver window. That window was an error saying that I didn't have my audio in line active, and after realizing that i could move that error window out from behind the splash screen, I was in business. I think the new version of vegas is great, and I'm glad that I am able to use it now with no problems at all.
#1355 |
Sponsor: JET DV
1. Vegas 5 does not author or burn DVD's so it doesn't have anything to do with +R or +RW discs.
2. It DOES create valid MPEG2 files, though.
#1356 |
Sponsor: JET DV
Good to hear you got it working.
#1357 |
what this means is that you may have previously installed Prem Pro on ur system and with it, inadvertanly installed an proxy ASIO driver which is conflicting with yrou existing ASIO drivers through a soundblaster card or any other card using ASIO HW drviers...
there is a fix for it, but right now, my net connection isnt letting me get to my other forum to fish it out for you.. stay tuned... |
#1358 |
there are many factors in ths situation.. primarily the media you are using, and the dvd authoring tool
some dvd players flat out refuse to play a disc for its make, while others wont play them due to the file system... you wont get 100% compatibility with every disc u make... one thing to note though, is that dvd architect1/2/3 has been designed with the DVDForum specs specifically for compatibility. Its file system protocol is identical to a commercial dvd, which gives it an advantage on the other aplications when it comes to compatibility... to save burning coasters, an idea is to use rewriteable dvd's as masters |
#1359 |
Rendering Order?
I wrote into this forum earlier this week about slow rendering in V5.
A 25 min clip, 80% mp2 and remaining avi's, no effects (pre-rendered) and a few masks, estimated time to render to mp2 = 14 hours. Does that sound accurate? I just dont recall rendering moving so slowly. So my question: I capture as full frame avi. Should I do all the editing, correcting, etc as an avi, then render it down to a 'flattened' avi or mp2 then insert, or import the footage into an existing project, work on it, then render the whole thing at once? Does this make sense? It is late and my computer is slow. |
#1360 |
what about rendering to another drive?
I have another internal 80 gig and an external firewire lacie. Any chances that would speed it up? Just got handled the probably impossible deadline... |
#1361 |
Vegas rendering chews up my cpu to 100%
I have made desperate attempts on this board and other to try to determine what is going on.
I tried to render an identical clip on a laptop (that I no longer have access to!!) and it completed right at five minutes. My xeon p4 cpu maxed out to 100% on the same clip, after 13 minutes I cancelled. What could cause this? It has been working flawlessly until recently. I would gladly reformat the entire machine and start from scratch, but I have a deadline for Wed night I have to meet and cant handle a 19 hour render on a 26 min video. Reinstalled Vegas with no avail. Any suggestions are GREATLY appreciated. |
#1362 |
RED Code Chef
1. which version of Windows?
2. which version of Vegas? Did you change ANYTHING at all? Xeon's are server processors and I don't know if these are on the supported list for example (although in theory it shouldn't make a difference, of course).
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#1363 |
Hey guys, thanks. This is just what I needed. Thanks again. Bob
#1364 |
RED Code Chef
When you say mp2 you mean MPEG-2? mp2 is MPEG-1 layer II audio, not
MPEG-2 video/audio. 14 hours to render to MPEG-2 might be right, you did not tell us how long this movie is. Personally I would not go out to AVI first and then to MPEG-2 unless you are using an external encoder (like Canopus ProCoder). Vegas can read MPEG-2 just fine. As I always say: MPEG-2 encoding is an art, it takes lots of time and practice, both from the encoder and the person operating it. Do not expect perfect "hollywood-dvd-quality" in an hour or something.
#1365 |
Thanks, Ed!
Ever since I applied the 6.0a upgrade from the Sony website, I have my beloved triangles back. Thank you for your reply.
Just so you know, when this happened to me last year with Vegas 5, you told me to re-boot and the triangles would return. You were right! But this time, they didn't until I upgraded to 6.0a from the Sony Media website.
Interesting, if true. And interesting anyway. |
