Vegas Video discussions from 2005 (Q1Q2) - Page 9 at DVinfo.net
Old January 7th, 2005, 07:41 AM   #121
I have Windows XP and there are no large pictures in the project and even more the source files are in MPEG 1 format and I'm rendering the video in the same format. Upon my friends advice I I tried to render the file on other HD (not the one where the source files are kept) and this time it worked fine. I'm still confused I had no such problems with Vegas 4 even when I rendered very complex projects, strange, I do wonder is this characteristic to Vegas 5?
Ineta Salna is offline
Old January 7th, 2005, 08:31 AM   #122
Sponsor: JET DV
Rendering FROM Mpeg1 TO Mpeg1 *could* be the problem. MPEG is NOT a good editing format. You'd honestly be better off taking the original MPEG file and rendering to a new DV-AVI file, editing with it, and then rendering back to MPEG1.
Render the way you are, every frame must be decompressed and then recompressed - even if you have not affect that frame in any way!
Edward Troxel is offline
Old January 7th, 2005, 08:43 AM   #123
Steve:
Correct, capture and print are done using Connect HD 1.5.2. Of course a future version of Vegas will have integrated capture / print, just like everyone else.
///d@
Dennis Adams is offline
Old January 7th, 2005, 02:27 PM   #124
anyone have any ideas then? im at my wits end.
Tony Webber is offline
Old January 7th, 2005, 05:47 PM   #125
<<<-- Originally posted by Dennis Adams :
///d@ -->>>
I thought Sony was attempting to position itself as a HDV 'pacesetter' rather than a follower?
Steve Crisdale is offline
Old January 7th, 2005, 09:57 PM   #126
Render a composite animation/video
I'm attempting to render a short video clip which includes an animation and a video, combined together into a single video image. I created a 1/4 frame mask for the video in the lower left corner of the animation.
The animation is a1.1 gig avi which plays very smooth by itself, but when rendered to mpeg format (so I can burn the movie to a DVD for set-top playback) the 1 gig avi is reduced to a 45-60 meg mpeg file. The quality suffers tremendously and the animation plays back with stutter.
I've tried adjusting the CBR and VBR settings, reducing the I-frame interval, set the "Video Quality" slider to "High", de-selected "Allow field-based motion compensation", and altered the "DC coeficient" up to 10-bit. All settings render out with poor results.
Any idea what settings would optimize the render of an animation?
Fear No Weevil!
Patrick King is offline
Old January 9th, 2005, 04:58 AM   #127
RED Code Chef
I can imagine resolution might be a factor in this as well. If you are
not watching the preview in full resolution some interpolation is
going on etc. What happens if you render at the preview resolution
(shown underneath the preview screen), ofcourse this will lower
your movies resolution... but if you want it to look bad that is okay
I'd presume.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old January 9th, 2005, 05:58 AM   #128
RED Code Chef
Have you upgraded to the latest version of Vegas 4 or 5 (depending
on which you are using)?
Old January 9th, 2005, 06:47 AM   #129
RED Code Chef
MPEG rendering is a difficult art, please use the search button
above, select the vegas forum and enter MPEG as keyword to
find lots of threads on the topic.
Although the quality of the MPEG-2 encoder bundled with Vegas
is good, there are better encoders out there.
I have no idea what you are getting at with this 1/4 frame mask,
but I would take this 1.1 GB (I presume uncompressed avi?) file
and load that into a new project. Then create an MPEG-2 file from
that, see how that looks.
Also make SURE all your settings are correct and the same, this
includes your project settings and your export settings. Make
sure interlaced/progressive is especially correct.
Old January 9th, 2005, 08:25 AM   #130
Yes, I am running 5.0b, I'll try upgrading to "d".
The audio envenlope problem seems to have only been for that one project, but I am still having issues with the pan/crop system.
Kevin James is offline
Old January 9th, 2005, 12:38 PM   #131
Fred Retread
Intangible VEGAS advantage
<<<-- Originally posted by Ray Sigmond : You're right Ed, and in addition to the features, the forum support and energy is first class. Most vegas users are extremely pleased and excited about Vegas. I can't say that for some of the others.
Regards,
Ray -->>>
I agree wholeheartedly, Ray. And regarding that support and energy, here's to Edward Troxel (and Rob Lohman). The resonsivenss and quality of support in this forum is high even by DVINFO standards. Sony should declare these guys as an asset on their Balance Sheet. Thanks guys!
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline
Old January 9th, 2005, 01:16 PM   #132
wmv
Hello. I don know why when working in PAL and exporting to wmv if i touch any settings i cannot use 25 fps.
I mean, if i take for exaple the 256 setting and render the project it looks ok. But if i do minar changes as changing audio mode to mono for exaple, and i come back to the frame rate setting it moves automatically to 30 fps. Writing 25 would not fix the problem because as you move bacj 30 fps are again selected.
Anyone has notice this? how can i fix this problem?
Miguel Lopez is offline
Old January 9th, 2005, 03:35 PM   #133
Sponsor: JET DV
Have you tried changing the zoom level in the Pan/Crop window? Perhaps you're not seeing it because it's too big to fit in the window at that zoom level.
Old January 9th, 2005, 10:47 PM   #134
The animation codec works well, if not the best to output files
Alain
Alain Aguilar is offline
Old January 10th, 2005, 03:48 AM   #135
RED Code Chef
Which version of Vegas are you using? Did you upgrade to the
latest version 4 or 5 of Vegas?
