Vegas Video discussions from 2005 (Q1Q2) - Page 61 at DVinfo.net
Old March 13th, 2005, 01:57 PM   #901
Photoshop instructions, which show you "stepwise" sepia toning:
http://www.photo.net/photo/sepia/index
You might just want to check it out even if you don't plan on using Photoshop, because they use multiple tones for the sepia look (and that looks better).
Glenn Chan is offline
Old March 13th, 2005, 02:07 PM   #902
Replacing Vegas Audio track
I have a sequence that I've created and when I inserted the video I deleted the audio track. Is there any way to get it back without having to re-insert it?
Thanks guys!
Steven VanHorn is offline
Old March 13th, 2005, 02:18 PM   #903
Sponsor: JET DV
Undo???
Edward Troxel is offline
Old March 13th, 2005, 02:19 PM   #904
Yea...it was saved and re-opened.
No hope of undo
Old March 13th, 2005, 04:35 PM   #905
Audio CD problem
I am trying to burn an audio CD using Vegas. WHenever I click on any CD options (including CD tab in preferences) system just hangs while it looks for CD drives. I have two different CD drives that are recognized by every other program but Vegas. WHen I click on burn track at once it does the same thing. The project file has one MP3 file as source, broken into 4 tracks, but I doubt that matters.
Any clues? Or is there a better way to burn an audio CD using Vegas (or Soundforge or Nero) ? SHould I be doing some kind of rendering and then a different program to burn, like I have to do with DVDs?
Bob Costa is offline
Old March 13th, 2005, 06:04 PM   #906
If you're saying that you want to get back the audio that belongs to a video event, then, yes, Excalibur's Orphan Wizard does just that (and visa versa too).
Gary
Gary Kleiner is offline
Old March 13th, 2005, 06:19 PM   #907
I figured it out
Right click on the event, open in trimmer, double click event, select audio only, drag to timeline.
Hope this helps!
Old March 13th, 2005, 06:56 PM   #908
Vegas 5 and VirtualDub plug-ins
I've heard that VirtualDub plug-ins are compatible with Vegas 5. Is it true, and how to use them in Vegas? For example, I downloaded DESHAKER plug-in for VirtualDub, which is compatible with Vegas as I red somewhere. So?
Plamen Petrov is offline
Old March 13th, 2005, 07:43 PM   #909
Hi
Yeah I loaded the clip into vegas media pool, right clicked properties and the rate is set to 50 frames. problem is the drop down menu used to change it is greyed out. I use D-VHS to capture so I have tried capturing from all over the place. Need to know how to change that frame rate down to 25.
Troy Haines is offline
Old March 13th, 2005, 08:53 PM   #910
Sponsor: JET DV
Many (but not all) can be used by loading them in the WAX plugin available at http://www.debugmode.com. You can also use the Frameserve software at the same location to frameserve to VirtualDub.
Old March 13th, 2005, 08:54 PM   #911
Sponsor: JET DV
<<<-- Originally posted by Steven VanHorn : I figured it out
Hope this helps! -->>>
That will work. The method Gary mentioned is faster and easier, though.
Old March 13th, 2005, 08:56 PM   #912
Thanks to all.
You're right, Edward. Is there anything that Excalibur can't do?
-Steven
Old March 13th, 2005, 08:59 PM   #913
Sponsor: JET DV
So you're saying when you go to Tools - Preferences you can't click on the "CD Settings" tab?
If that is the case, you may need to contact Technical Support to see if they can help.
Old March 13th, 2005, 09:00 PM   #914
Sponsor: JET DV
Anything? Yes. But we're working on that too! :-)
Old March 13th, 2005, 11:52 PM   #915
Anyone using this?
EZ Keyboard:
http://www.videoguys.com/EZkeys.html
If so, what do you think of it? And -- are there any other similar options out there?
Thanks --
James Binder is offline
