Vegas Video discussions from 2005 (Q1Q2) - Page 47 at DVinfo.net
Old February 24th, 2005, 12:37 AM   #691
You can use any graphic file by browsing or dragging to Button Properties>Graphics>Thumbnail
If you are talking about a frame from the video that the button represents, just change the Start Time.
Gary
Gary Kleiner is offline
Old February 24th, 2005, 05:32 AM   #692
Thanks. But I'm not looking at changing the start time so much as I am looking to change the graphic that is represented (but still starting at frame 1)
Brian Burns is offline
Old February 24th, 2005, 06:23 AM   #693
you shoudl also check your temp storage capacity, preview ram settings too (i used to have mine on full and i got stack dump errors bascailly runnign out of memory... )
the longest render ive had though, was for black barred 4:3 footage, runnign colour corrections and colour curves and ive had the longest render be 27 hours.. for 2 hours worth of material..
im only runnign a P4 non HT 2.4, with 1gb ram..
Peter Jefferson is offline
Old February 24th, 2005, 07:13 AM   #694
HDV in Vegas 5.0 Trial Program
Hi all,
I've got the trial version of Vegas 5.0 (which is very nice I might add, i think i'll buy a copy) in which I want to do some really basic HDV editing with a FX1 which i'm borrowing this weekend for a test to see if i'll like the camera before i buy it.
Can I edit HDV with the Vegas 5 trial program & what plug ins do i need? Can you download the plug ins as a trial?
James Darren is offline
Old February 24th, 2005, 07:18 AM   #695
Pick some cool music first, and the editing ideas will come.
Bob Costa is offline
Old February 24th, 2005, 07:55 AM   #696
Why doesn't Vegas just capture it on its own??
thanks
Brent Marks is offline
Old February 24th, 2005, 08:21 AM   #697
Sponsor: JET DV
If you change the timecode where Gary indicated, it WILL change the graphic to what is at that timecode but WILL NOT change where the chapter points to.
Edward Troxel is offline
Old February 24th, 2005, 09:07 AM   #698
I think Cineform.com has one for Vegas (Connect HD), but I do not know if it will work for the demo version of Vegas. U can ask David and the folks at Cineform to answer that question. Also, if my memory serves me right Vegas will not natively capture, but it will natively edit HDV content once imported into its media pool(though it is probably slow without the plug-in).
Dwight Flynn is offline
Old February 24th, 2005, 09:18 AM   #699
<<<-- Originally posted by Dwight Flynn : Vegas will not natively capture, but it will natively edit HDV content once imported into its media pool(though it is probably slow without the plug-in). -->>>
i'm a bit confused... how do you capture the DV from the FX1 then?
Old February 24th, 2005, 12:12 PM   #700
I thought the issue was the capture (and edit) of HDV, which I am be wrong about, but I believe Vegas does not capture (but can import if already on the hard drive). Now I know it works this way for the JVC HDV cam, though I am not certain about the FX1, but it may be the same.
Old February 24th, 2005, 01:30 PM   #701
Using Cineform's HDLink, you can digitize, then import into Vegas.
Sean M Lee is offline
Old February 24th, 2005, 02:12 PM   #702
<<<-- Originally posted by Brent Marks : Why doesn't Vegas just capture it on its own??
thanks -->>>
An excellent question that I've been asking for a while... without any truly valid response.
It's a shame, because such a glaring oversight - considering the perception that Vegas IS also a Sony product, will not help the Vegas cause against any competing NLE that gives FX-1/Z1 users direct capture capabilities.
You can capture directly to Vegas if you set the cam to DV downconvert.... but why when HDV is what people bought the camera for?!!
Steve Crisdale is offline
Old February 24th, 2005, 02:26 PM   #703
I bet more is available after NAB...be patient grasshopper. : )
Old February 25th, 2005, 01:55 AM   #704
<<<-- Originally posted by Sean M Lee : I bet more is available after NAB...be patient grasshopper. : ) -->>>
Oh I can wait.... that's what I've had to do up until now, so a little more isn't going to destroy me :)
It's just a shame that as a Vegas user, I feel compelled to be honest enough when the question is asked "what NLE would you advise for use with the FX-1?", that I have to say "I use Vegas, but you will need to consider a 3rd party codec to capture from the cam".
You know a potential user of what could be the most elegant HDV solution available, may be lost to this one 'Achilles Heel'... And that isn't my loss, if they don't end up using Vegas, but it doesn't make me feel any better either...
Old February 25th, 2005, 08:28 AM   #705
Steve,
Being the first is nice, being accurate is better. Avid won't have their HDV capture active untill after NAB either. I use Avid, and I can wait. Don't worry about it.
Richard Alvarez is offline
