Vegas Video discussions from 2005 (Q1Q2) - Page 38 at DVinfo.net
Old February 14th, 2005, 10:17 AM   #556
Sponsor: JET DV
What drive have you specified for your "temporary files"? The audio ALWAYS gets rendered to a W64 file. By default, that will be on drive C - you may not want it there.
Edward Troxel is offline
Old February 14th, 2005, 10:47 AM   #557
Glad you got it figured out. Computers sure can be fussy at times, eh?
Christopher Lefchik is offline
Old February 14th, 2005, 11:52 AM   #558
It's version 5.0b build 160
The problem happens with both stills and clips that display correctly at other places in the timeline.
Forget what I said about it happening after the clip is there for awhile - I just replaced a problematic clip only to see the same line appear in it's replacement. (I tried this delete and replace technique once before with success.)
In some cases the line goes across the bottom as well forming a sort of box within a box effect.
All clips have are defaulted to "Maintain Aspect Ratio".
thanks
Lorraine Boyle is offline
Old February 14th, 2005, 11:58 AM   #559
Sponsor: JET DV
How about a snapshot as to what you are seeing (I'm not picturing what you're describing).?
How about a way to reproduce to see if we can produce the same results?
Or maybe a copy of the VEG file into which we could drop our own media to see if we get similar results?
Old February 14th, 2005, 01:49 PM   #560
Thanks, I will give that a go.
http://www.veoh.com/channels/filmmaker
My clips and films.
Bob Benkosky is offline
Old February 14th, 2005, 03:24 PM   #561
Let's say I shoot in CF25 in HDV mode and then capture the footage without downconverting. I could then change the frame rate to 23.976 and then down convert to NTSC DV 24p right?
Greg Jacobson is offline
Old February 14th, 2005, 05:23 PM   #562
ROB!
THat did it. Actually, I found it was ok to keep "Minimum Clip Length" checked at 1 second. But what I needed to do was turn "SCENE DETECTION" OFF. I had it "ON" for all the other modes. CF24, it must be off.
Thanks. Now you can effectively capture ALL MODES in the HVR-Z1U with Sony Vegas Capture 5.0. Just make sure Scene Detection is OFF when doing so. (you shouldn't need it for a 'live' capture anyhow. *smile*
- Shannon W. Rawls
Shannon Rawls is offline
Old February 14th, 2005, 07:25 PM   #563
Can Vegas5d capture HDV right in the program???
Or is a 3rd party capture tool needed?
thanks!
Brent Marks is offline
Old February 14th, 2005, 09:02 PM   #564
Greg -- please post that question in our HDV Editing forum. Thanks,
Chris Hurd is offline
Old February 14th, 2005, 09:10 PM   #565
<<<-- Originally posted by Dennis Adams : It's not because it's upper first, it's because it's not DV, and Vegas 5 only does pulldown removal on DV. You can downconvert HDV CineFrame 24 to DV and remove the pulldown if you wish.
///d@
Sony Media Software -->>>
how?
Old February 14th, 2005, 11:34 PM   #566
Why can't I add/find envelopes?
Newbie question..
I read in the help file how to add supersampling. It says go to the video track, right click, and insert a supersampling envelope.
I tried that, but it isn't offered as a choice in the context menu. Neither is Motion Blur. The only choices I get on the video track are Mute, Composite Level, and Fade to color.
So how can I add a motion blur envelope and / or a supersampling envelope? I've yet to see any menu choice that offers either...
Jay Hancock is offline
Old February 15th, 2005, 08:23 AM   #567
Sponsor: JET DV
Supersampling is added on the Video Bus track. To to View, Video Bus Track, and then you can add the envelope there.
Old February 15th, 2005, 12:07 PM   #568
Crop problem
I was working on a project and I noticed a few clips where I could see a portion of my matt box in the right corner of the shot. So I figure no problem I'll just crop the clip so I does'nt show.
After viewing the result I decided I wanted to change it but it was late so figured I'd do it the next night.
So the next evening I opened up the project and had at it.
I clicked on the pan/crop button in the event, when it opened I right clicked and hit restore so I could try something diffent but it did not restore.
I tried it many times on the different clips I needed to change but they would not restore.
In desperation I tried a few things with no luck. Untill I hit the effect button on a clip, put a effect on it, then took it off and walla.. The orignal clip un-cropped was back!!
So I changed all the clips this way but when I played it back some off then were changed back to cropped again!!
There was no alcohol involved and I did'nt do anything fancy the night before. Just the usual editing like I've done before.What is going on??
I don't think I turned anything on to cause this in the options list because I did'nt go in there. maybe a tool bar button?? I also tried a re-boot with no luck.
Any help with the one will save me my sanity......
Thanks as usual.
Ron.G
Ron Guilmette is offline
Old February 15th, 2005, 01:21 PM   #569
Sponsor: JET DV
Any way to provide steps to reproduce? I just did some quick testing and could not get that to happen. Of course, I'm not sure I completely followed everything you did.
i.e. start with new project
Add media
etc...
Old February 15th, 2005, 02:27 PM   #570
basically I started a new project with the standard 60I default template. Drag and drop from the media pool to the time line then edited the clips of what I wanted using the "split clips" function and deleting the unwanted portions from the time line.
Made some transitions and direct cuts (nothing fancy) and then I did some pan and crops on the clips that needed it.
I clicked on the Pan/crop button for the clip and made my changes. The preview window would update to those crop changes just as it should.
After viewing I decided I did'nt like the out come so I saved the project with the save command (not the save as dialog)
So I could resume the project the next night.
Last night I started up the project to fix the cropping and when I clicked on the Pan and crop button in one of the clips then right clicked in the crop window to bring up the restore menue, then hit restore, I did nothing.
I move the crop box around but the preview window did not update. I tried the sync to curser on and off. Nothing.
Then just for the heck of it I hit the effects icon for the same clip and applied a effect. Then I deleted the effect and the clip was no longer cropped . It was restored like I wanted it in the first place.
Your reading it right, it just does'nt make any sence at all.
I have no idea what is causing this but I'm gonna mess with it again tonight and see if I can figure it out.
