Vegas Video discussions from 2005 (Q1Q2) - Page 121 at DVinfo.net
Old June 9th, 2005, 07:29 PM   #1801
Hi Neil,
Sounds like you are frustrated! Here's a couple of things to think about or try...
Most TV sets (and monitors) will overscan the TV signal they display. The 5% or so you mention is reasonable. Fancy (professional) monitors have an underscan switch which allows seeing the entire frame. I'm not sure if your monitor has this or not.
Also, its not clear if you've tried this, but right-click on the Preview Window and select "Simulate Device Aspect Ratio." This may help solve the "squished" picture.
Hope this helps....
Cheers,
-Matt
Matt Ockenfels
a pixel a day keeps boredom at bay
Matt Ockenfels is offline
Old June 9th, 2005, 08:22 PM   #1802
thanks Edward
Vince Debart is offline
Old June 9th, 2005, 11:27 PM   #1803
That's the most concise thread of all time. :-)
DJ Kinney is offline
Old June 10th, 2005, 07:52 AM   #1804
Sponsor: JET DV
Would have been shorter but the forum software requires a minimum of 10 characters. My first attempt was "Yes." :-)
Edward Troxel is offline
Old June 10th, 2005, 11:43 AM   #1805
problem: no audio while capturing.
While I'm capturing, I only get a video preview but no audio. Is there some option I should be selecting to hear the audio during capture? Or is this normal in Vegas?
EDIT: oops, I found it... it was just in the capture window options.
J.
Jan van den Hemel is offline
Old June 11th, 2005, 01:34 PM   #1806
Jacket Picture creation in DVDA2
Anyone using this, how is it? Is this for producing the whole insert or just exporting stills to another software?
Vince
Old June 11th, 2005, 01:36 PM   #1807
sorry that should be DVDA3
sorry that should be DVD3A not 2
Old June 11th, 2005, 09:21 PM   #1808
Sponsor: JET DV
It's for specifying an image that should be displayed when the playback of the DVD is stopped. Not all DVD players support Jackets. Others require that it be turned ON in the menus. It has nothing to do with exporting images or creating inserts.
Old June 11th, 2005, 11:13 PM   #1809
Vegas 5: Codec Reassurance
Hi. This is a really stupid question, but I just wanted to make sure of something. I think I'm using the default Sony DV codec but I'm not sure. I have the option "not use third party codecs" on, and I have the "use Microsoft codec" off. According to the manual and the helpfile, this should ensure that I'm using only the Sony DV codec right?
The only reason I ask, is that when I click on a file in the media pool, the properties in the taskbar only list "DV" as the type of codec used. This means Sony DV, right?
Thanks.
Robert Kirkpatrick is offline
Old June 12th, 2005, 04:06 AM   #1810
RED Code Chef
Do you mean you want to change the pitch over time? Through something
like key framing or external automation? Which version of Vegas? I don't
have Vegas with me at the moment so I can't check the first option for you.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old June 12th, 2005, 05:26 AM   #1811
Sponsor: JET DV
As long as "not use third party codecs" is on and "use Microsoft codec" is off then you are using the Sony codec.
Old June 12th, 2005, 06:07 AM   #1812
RED Code Chef
What kind of "breakup". Does this happen with when the "movie" inside the
button is repeating back to the beginning?
p.s. I've renamed your thread. Please use descriptive titles. A title like
"Dvda2 ?" does not tell anybody what your question is. A lot of people will
simply not read such a thread for that reason alone.
Old June 12th, 2005, 06:29 AM   #1813
RED Code Chef
Also keep in mind that by default the preview screen in Vegas will display in
square pixels. Make sure you select "emulate device aspect ratio", it should
look normal.
As Matt explained, any consumer TV will chop of a bit of the sides and top
and bottom. That is normal.
Old June 12th, 2005, 06:43 AM   #1814
Thanks for the thread tip...The video starts ok then about 30 sec in the brake up starts. in this project I have to buttons they both have the break up. its like a flash or a jump cut and some of the other break up has lines through it. the cut of music is about 4 min. long is there a default on the amount of time the video plays or is it the same amount of time as the cut of music
Vince
Old June 12th, 2005, 06:47 AM   #1815
thanks Edward
